Can it be ?, No capacitance.
http://www.gwinstek.com/en-US/products/Discontinued_Products/Discontinued_Meters_LCR/GDM-8251A
Tom
Unfortunately it doesn't. But this is where other equipment comes in to pick up where a particular bit of gear falls short for you (compromise bit).
Better yet, it can be less expensive to do things this way, depending on what you need in terms of range and accuracy. For example, the Uni-T UT139C includes capacitance for all of $30 shipped to your home (no need to worry about airline restrictions). So do other handheld DMM's, which are typically less expensive for the features vs. bench meters.
But perhaps the ranges in a DMM isn't quite sufficient (or you need inductance and/or better range/accuracy for resistance).
At which point an LCR meter would be the right tool for the job, and more cost effective as well with a DER EE DE-5000. Not much more than a decent dedicated ESR meter (not enclosure-less projects).
Also keep in mind that LCR meters generally have a wider range and better accuracy (4 wire measurements across the board) as that's specifically what they're made for.
In the case of the DE-5000, take a look at the following (from the
manual):
Just in case you're not aware, the max value of 200mF = 200,000uF, so handy for large caps you might use for audio work.
Pricing for LCR + TL-21 & TL-22 test fixtures:
- Amazon (US to US) = $132.88 shipped (scroll down and it'll show the meter + fixtures)
- eBay (Japan to Israel) = $133.97 shipped (price includes LCR + both test fixtures)
One thing to note about this unit (and many others), is there's no input protection whatsoever. So make sure any capacitor you hook up is discharged
prior to attaching it to the LCR meter (will save your meter and a lot of swearing).
In short, it will be useful for audio IMHO (LCR with a sweeping AC signal would be even better, but is way out of your listed budget as they go for ~$2K or so last I checked). And at a budget of $500, you'll still have ~$150 left over after buying both the 8251A linked and the DE-5000.
Brief article that might be of some help in figuring out what the above measurements are (
How to Use an LCR Meter).
Oh, this particular LCR meter has a USB & Software kit available as well as an AC power adapter. Not quite a bench unit in terms of form factor, but is in terms of features. And the reduced footprint on the bench is nice bonus IME.
Hope this helps.
