Thanks Barry,
Your answer helped me confirm what I thought those values represented. After your remark regarding that the specification are related to the arbitrary waveform mode, I installed the software that is used to create arbitrary waveform and I see the that the software always breaks the waveform into 16000 horizontal points. That put the 16Kpts wave length specification into perspective really nicely.
I do have a followup question though. In your reply, you said that all those specification referred to the arbitrary waveform and I am wondering if you really meant to say that or if it was a typo. In other words, are the specifications really just for arbitrary waveforms or do the specifications also relate to the built in standard function such as Sine, Square, Ramp, Pulse and Noise? After all, aren't the built in functions basically pre-built arbitrary function?
Thanks.
