Author Topic: Help me pick an o-scope, $3k budget  (Read 5373 times)
Offline CraftyAndyTopic starter
« on: August 20, 2018, 06:38:32 pm »
Hi there,
I'm looking to purchase an oscilloscope and would like some input.
Here's what I'm planning on measuring:
1) Relatively high voltage (>60vdc), and high current (>200A)
2) Relatively slow signals
3) rs-232 or CAN decoding
4) Would like 4 channels
Other considerations:
1) May be used in a manufacturing environment where calibration certificates are needed
2) I don't mind a headless option (PicoScope grade), as I am very comfortable using my laptop for this
3) $3k (USD) budget for scope + all accessories needed for high voltage and current
My top choice right now is shown in the attached image below, it winds up being ~$2k (USD) and I believe it accomplishes everything I want and sets me up with a nice base unit if I wind up needing more differential inputs. I'm not sure if I'll have the resolution I want with the 25:1 differential probe and a ~60vdc signal, but with the leftover money I could get another one of their probes (70/700v differential probes are available)
I see a lot of people suggesting to not go the headless route, which I understand, but I'm curious given my requirements and considerations if this is my best option, or if there's another option out there that'd be better.
I may be open to used, but would need it to be from a reputable source in case there are issues or calibrations that need to be redone.
Thank you for any input!
The following users thanked this post: petrinch
Offline Andreas
Re: Help me pick an o-scope, $3k budget
« Reply #1 on: August 20, 2018, 08:16:03 pm »
Hello,
If the application is automotive: why not use a PicoScope 4425 with up to +/-200V direct inputs?
Probably you will not need any 10:1 or 25:1 probes.
The PS4444 is more for mains voltage/motor control development.
with best regards
Andreas
The following users thanked this post: Lomax
« Reply #2 on: August 20, 2018, 08:26:14 pm »
Not automotive strictly, rather high power brushless motor test and development. The 4425 does look interesting, and some of the kits come with what I'd want. I didn't see the 4425 as it's down in the "automotive" section, rather than the general oscope section, thank you for the suggestion!
I'd assumed there would be more people advocating for a unit with a screen.
Offline fonograph
  • Country: at
« Reply #3 on: August 20, 2018, 08:40:22 pm »
I would go for used Keysight/Agilent 3000X series,the one without touchscreen.They can be hacked to unlock full bandwidth.
Offline tautech
« Reply #4 on: August 20, 2018, 08:59:47 pm »
Hmmm, your understanding of calibration tractability might need updating. Most new modern equipment comes with a Cal cert listing the equipment used, their individual SN#'s and the dates that each of their calibration's expire.
Further calibration checks are verification that the instrument still meets either datasheet spec or the performance specification listed in the service manual. These comparatively simple checks can be done in most Cal labs with just calibrated voltage and frequency sources and a Cal verification is issued.
As most modern equipment is 'closed case' calibrated/adjusted it's more important that your local Cal lab has the specified or equivalent equipment to undertake adjustments should any be necessary to bring an instrument back into spec.
Then to be completely sure of your 'system', current and differential probes need be checked as meeting spec too.
What you require doesn't appear to be demanding at all and many cheap entry level scopes could achieve your requirements and at considerable cost savings. If current measurements are required to be accurate this is where I'd be looking for improvements in choice of equipment. What are the current measurement requirements ? AC, DC or both ? Frequency ?
Avid Rabid Hobbyist
« Reply #5 on: August 20, 2018, 09:07:54 pm »
I googled a bit and didn't find much about this option, are you able to elaborate?
I agree, I come from a background where calibration has not been important, and am now in a position where it is. I don't know what it is other than "calibration". I wasn't sure if this meant certificates, or actual tweaking of pot's to get the measurement to line up with reality. It sounds like it's typically more on the certificates side of things.
The currents are both AC and DC (AC at motors, DC at battery). Low frequency on the AC, but will be interested in viewing transient events on the power bus.
Thank you both for your input and assistance!
Offline tautech
« Reply #6 on: August 20, 2018, 09:18:28 pm »
So you properly understand, there are zero physical adjustments for Cal procedures in modern equipment.
Download a service manual or two and study the required procedures.  ;)
This is where you can spend your entire budget on a good AC/DC current probe and the primary reason why I say most entry level DSO's and especially those with good remote connectivity capability can save you a bundle of cash to spend on the bits that really matter to obtain accurate results.
Avid Rabid Hobbyist
« Reply #7 on: August 20, 2018, 09:37:35 pm »
I understand that now, I knew it was a possibility previously but wasn't certain. Once I determine which scope I'll be purchasing I'll be reading the manual (and service manual) cover to cover unless you suggest it's a good practice to do prior to purchasing
That's the kind of information I'm here to gather. I'm not sure if I'm on the right track with my picoscope cart above, or if I should be considering something different. It sounds like the measurements I'm trying to make lead to a low end-scope with high end probes, is that an accurate summary in your opinion?
Thanks!
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #8 on: August 20, 2018, 09:39:30 pm »
since you ask opinion and you havent ban me... no its not the best choice. i wouldnt waste my money on PicoScope i smell blood sucking brand there. if you are happy to carry around automotive your laptop and the usb scope and dangling wires on your rib then carry on, i'll buy hantek (or migsig?) portable/handheld dso for that purpose. i'll save most of the money in the list, even my rigol DS1054Z can do your requirement. the wisest thing on your list is just the current (or/and he differential) probe, whats not wise about them is their D9 connector.
Offline tautech
« Reply #9 on: August 20, 2018, 09:51:00 pm »
Thanks!
Yep......well sort of.
Current probe AC frequency requirements will dictate what you have to spend along with the resolution/accuracy required.
As Mech points out more looking/research is needed.
Avid Rabid Hobbyist
« Reply #10 on: August 20, 2018, 09:51:51 pm »
I've seen a lot of people suggest the Rigol DS1054Z, that's one of the things that caused me to pause before hitting the "buy" button and come consult some people with more knowledge than I on this subject.
Thank you for your input!
« Reply #11 on: August 20, 2018, 10:07:39 pm »
The TA301 ammeter attachment has a 20khz frequency per http://www.farnell.com/datasheets/2265784.pdf?_ga=2.27976124.1645628915.1534802263-1531057897.1534802263
With motor speeds in the 100Hz range this seems reasonable to view the AC into the motor, as well as transients in the DC bus.
The TA301 in the 200A range setting should do fairly well for us in most all situations. Only rarely would we bump it to the 2000A range where we may be losing some resolution.
Looking at Rigol accessories, they didn't appear to have probes for the 1000 series that were a great fit for my needs.
Thanks again for your input!
Offline TK
« Reply #12 on: August 20, 2018, 10:08:57 pm »
The micsig TO1104 in tablet format with touch screen is a good option.  It has 4 channels, 100MHz and if you buy the full option for around $500, you get the serial decode option enabled, 28Mpts memory and battery.  They also manufacture the DP10013 which is a differential probe for around $150.
« Reply #13 on: August 20, 2018, 10:14:13 pm »
I like the looks of that DFP10013 probe, thanks for the tip! I'll look into the TO1104 more as well, much appreciated!
Offline fonograph
  • Country: at
« Reply #14 on: August 21, 2018, 01:06:47 am »
If you have 3k $ budget,stay away from anything Chinese no matter what anyone suggests to you.The way they handle bugs is simply outrageous and unacceptable.Get some Rohde & Schwarz RTB 2000 or Keysight 3000X.
Offline TK
« Reply #15 on: August 21, 2018, 01:14:40 am »
$3K budget including current and high voltage probes... I think R&S and Keysight are out of range...
Online Fungus
« Reply #16 on: August 21, 2018, 09:08:52 am »
Ignore the people who only read the title and thought "He wants a $3K oscilloscope!".
With those requirements you need an entry level oscilloscope and some very fancy probes.
(ie. No real bandwidth requirements, just high voltage/current)
That said: At those power levels a simple shunt will do for looking at the current and a simple (but enclosed) voltage divider will work for the voltage.
For working with those shunts you'll need something that works well in the mV ranges (or put two or three shunts in series). Maybe something with 12-bit resolution so now we're full circle back to expensive oscilloscopes.  :-DD
« Last Edit: August 21, 2018, 09:13:08 am by Fungus »
Offline Andreas
« Reply #17 on: August 21, 2018, 09:41:15 am »
Hmm the prices seem to have higher priority than the specs which are still not clear:
- do you really want to spoil the accuracy of a normal current clamp (1%) by the gain error of a 8 bit scope (3%).
- how many sample memory is necessary e.g. for measuring a complete run up phase of the motor including (parallel) CAN message sampling.
- are pass/fail masks necessary for the production
- is the scope only needed for viewing or is the measured data (complete or screen shots) to be stored on a PC.
- is remote control for the scope needed (e.g. by remote desktop)
- how often is the zoom function needed (and how easy can it be handled).
with best regards
Andreas
« Last Edit: August 21, 2018, 09:44:19 am by Andreas »
Online Fungus
« Reply #18 on: August 21, 2018, 10:27:10 am »
Do you really need to know the current of a 200A motor to 3 decimal places?
You should probably be adding 50% (or more) to the power supply and wiring specifications, so 3% accuracy is plenty  :-//
Building a shunt into the motor might be a good idea anyway, for on-site diagnosis, etc.
Edit: If you want more decimal places it's probably better to buy more accurate shunt ($20) and add a $5 op-amp module to it rather then spend an extra $1000 on the oscilloscope. This setup will work on-site, too, when the maintenance guy connects up his Fluke and sets it to min-max mode.
« Last Edit: August 21, 2018, 10:37:30 am by Fungus »
Offline mzzj
« Reply #19 on: August 21, 2018, 12:06:54 pm »
OP wanted to measure current transients (20khz current clamp was also mentioned)
Normal 60mV 200Amp shunt is borderline useless at 10khz because of the self-inductance. Coaxial shunt's have much better high frequency response but more tricky to mount and price/availability sucks.
Online Fungus
« Reply #20 on: August 21, 2018, 12:34:45 pm »
Won't it be background noise compared to the inductance of the motor?
« Reply #21 on: August 21, 2018, 03:24:27 pm »
Thank you everyone for some good questions, I believe I've addressed most of them below.
I'd prefer to stay away from a shunt to keep wiring easier (no need to add a shunt inline), but from a price stand point it may be worth me reconsidering this. I hadn't considered it initially so I will have to now.
Very good point, I should have been more explicit in my title/OP. Thank you for pointing this out.
I do want to measure transients, but I don't expect they will be in the 20khz range, rather that the clamp I'd initially looked at should be sufficient to view transients as its response is (relatively) quick.
Would prefer to get above 8 bits if possible. The picoscope 4444 accomplishes that.
Hard to know how long of a sample is needed, longer is better ;D A few seconds should be sufficient.
No plans for this, although the fact the picoscope has it doesn't hurt
Would like the ability to export to CSV or similar for post-processing in excel
No immediate needs or plans for this
Zoom is important, I'm not sure if a knob or a mouse will be easier for me, but I'm comfortable with both.
No, to 1's place is fine in all honesty...
Online Mechatrommer
  • Country: my
« Reply #22 on: August 21, 2018, 05:40:14 pm »
you must have a very good reason for spending $1K+ on USB 14 bit scope, such as in audio-not-phoolery business try looking at THD, or a higher resolution FFT. probing 200A even down to mA resolution is not good enough reason, 14 bit aint going to cut it anyway, you need at least 18 bit. and there is a better way of doing that in $300 standalone (bench or handheld) scope. first you need to know what you are doing (which i suspect you dont), and then you can make a better list. why dont you just buy $300 8 bit scope (most recommended instead of something not recommended) and learn how to probe what you wanna see, or wiser ask in forum for that particular subject. a few members here are x-generation since DS1052E (upgrade to DS1054Z due to better performance) and never regret the advice from Mr Dave Jones, whose videos you need to hear from time to time.
beside the $300 rigol/siglent/hantek whatever china brand recommended you are going to need current probe, since you mentioned DC, so you need hall effect type such as this but if you really hate china, you can get $900+ this used but then it only goes to a few Amp, iirc there is big clamp from Fluke (expect another $1K+++++) but they only do AC, and then soon you will realize what you probably are asking for a fortune on current probe alone. ymmv.
« Reply #23 on: August 21, 2018, 06:48:54 pm »
Hi there,
Thank you for your input. I'm not sure why you feel I don't know what I'm doing, I feel that my responses to the questions thus far have been informed and addressing the point.
The tektronix probe you linked below is the style I used at my last job. I have fairly extensive oscilloscope usage experience, but I've never had the pleasure (or pain) of picking one out and buying it. That part I'm very new to, and is why I've spent time researching it and asking questions about my proposed shopping cart.
If you have any input on the proposed cart and its ability to accomplish what I've mentioned I'd appreciate the input.
Thanks,
Online 2N3055
  • Country: hr
« Reply #24 on: August 21, 2018, 07:52:46 pm »
For your stated requirements that Picoscope cart will serve you quite well.
Picoscope is good equipment, and if you don't expect it to be full replacement for a scope with  buttons and screen they are excellent.
That scope, in addition to high res, has fully differential inputs.
I have both Picoscope (not that model) and standard scope, and I use Pico quite often.  No button-twiddling scope has 24" screen...
It also have advanced math etc etc...
