Author Topic: Help me understand demodulating with the DSA815  (Read 1647 times)
Offline josephny
« on: October 23, 2015, 07:38:59 am »
Can someone explain why the following happens:
I generator a 400mhz carrier FM modulated with a 1Khz tone and feed it into the DSA715 SA
I see the signal displayed.
I turn on DEMODULATE, plug in a headset and I hear the tone go on and then off and repeater (a pulse).
I then tuned the SA to a local FM broadcast, did the same thing and heard the broadcast station in the same way (1/2 second on, 1/2 second off).
I played with "demod time" but it didn't get rid of the on/off pattern.
What am I doing wrong?
Thank you!
Online TheSteve
  • GHz or bust
Re: Help me understand demodulating with the DSA815
« Reply #1 on: October 23, 2015, 08:37:04 am »
You're doing nothing wrong, the spectrum analyzer is "sweeping" a single frequency. Even if the frequency isn't changing it is effectively restarting the sweep each time at an interval determined by the "demod time".
Moral of the story - a spectrum analyzer isn't a standard receiver.
VE7FM
Offline vk6zgo
« Reply #2 on: October 23, 2015, 11:59:47 am »
Unless it is an old analog HP,which will happily act as a receiver.
Offline josephny
« Reply #3 on: October 23, 2015, 12:04:02 pm »
I see!
So even at zero span, it's restarting it's measurement at the interval that "demod time" is set to.
Thank you so much!
Offline Electro Fan
« Reply #4 on: October 23, 2015, 04:28:08 pm »
What models would constitute an old analog HP (where is the demarcation in their models between old and new?)
Offline George_Race
    • Race Consulting
« Reply #5 on: October 23, 2015, 08:49:23 pm »
Any of the HP 8590 series will give you excellent audio either AM or FM.  Just make sure it has option 102, which is the AM/FM demodulator board.  No matter what the scan you will hear a constant good signal on AM or FM, and you can do Zero Scan as well with the same results.
I had a new DSA815 and sent it back for that exact reason.  Also the Rigol front end sensitivity was not anywhere near as good as the HP 8595E that I purchased to replace it.  You can purchase one of the 8590 series HP SA's for about the same price, or less than the DSA815.
Hope this helps..............
