FWIW, I do a fair amount of power supply design and debugging, and find that I frequently use 3 or 4 channels, and there are times when I wish I had more. When you have to start chasing down gate drive delays, startup, issues, etc., it is almost essential. If you are chasing failures, you can capture more stuff and look at it later, so yo don't have to keep the DUT running any longer than necessary.
Also, if you are working on high density power electronics, you may find yourself probing DFN gate drives right next to a few hundred voltages and a low impedance bus. I don't know about you, but I don't like moving probes around when a false move can fry the circuit, the probe, and you. Even a slip at the signal level some distance away can still result in exploding power parts.
John
