Yeah, it's a PD part number. Seems to be the number they use for just a plain old switching diode, about the same as a 1N4148. Try that. I promise it's not a Zener, at least - they use VR instead of CR as the reference designator for those.
Obviously it's a bit bigger, so it'll have a higher power rating, but they do use them in low power signal applications. Use your best judgment as to whether you need to go for something bigger - in that case a 1N4004 should suffice.
