Author Topic: HP 8133A Pulse Generator Service Manual  (Read 169673 times)
Offline EVlabTopic starter
« on: September 20, 2018, 07:22:36 pm »
Hi all!
I'm looking for a service manual for the HP pulse generator 8133A.
Can someone help out?
Offline jhenderson0107
    • Elk Engineering
The following users thanked this post: EVlab
Re: HP 8133A Pulse Generator Service Manual
« Reply #2 on: September 21, 2018, 11:33:54 am »
Thank you very much!
Offline bson
« Reply #3 on: November 04, 2018, 04:12:58 am »
Did you ever find a schematic for this instrument?
« Reply #4 on: November 04, 2018, 08:08:20 pm »
Yes, it's easy:
1) go to http://www.ko4bb.com/getsimple/index.php?id=manuals
2) type 8133A into search box (it's not listed in the directory)
3) have fun (and tell me where to get a cheap 8133A)
Offline bson
« Reply #5 on: November 04, 2018, 10:08:02 pm »
Ah, I looked through the directory but didn't realize there are unlisted documents, including an 8133A service guide!  Excellent!
Offline bson
« Reply #6 on: November 05, 2018, 03:43:29 am »
Well, I bought one as a project to see if I can fix it up... No idea what inside the case, or even if it's board complete, but the seller accepted what I thought was a reasonable offer so I'll take a look.  This is the one I bought: https://www.ebay.com/itm/232976283208
Will try to arrange to go pick it up tomorrow.
It COULD be easy to fix.  Could also have had boards pilfered and I'm stuck with a bad power supply and broken front panel and nothing else.  I guess I'll find out. :)
Without a service manual available I wouldn't have bothered...
Offline bson
« Reply #7 on: November 06, 2018, 09:26:39 pm »
Wow, this is a monster... built like the proverbial brick outhouse.  It must weigh 60 lbs at least.  So, picked up the 8133A, got home and powered it up to see what happens, if there are any beeps, POST messages, fans come on, whether it responds to GPIB, etc.
It comes on.  I poke around a bit.  It works fine.  Checked some low frequency stuff with the scope.  Will check 1-3GHz output with the counter.  Perhaps it has some problems with certain kinds of outputs or something.  Keyboard seems okay, not too snaggly.
So I'm leaving it running for a few hours to see if it has any thermal issues.  Then will open it up and give it a good cleaning, check caps, etc.  I bet it either had a loose connector that resettled during transport (or because I stood it up sideways perhaps) or some other trivial problem.
Well, that has worked out alright so far. :)
Offline Xtremexp
« Reply #8 on: September 29, 2023, 04:49:16 pm »
Did anyone find the schematic of 8133A?
Thanks!
