Hi guys,
I recently scored a HP 8663A signal generator, and it basically works fine, but I have two small questions, also asked on the HP/Agilent mailing list, but so far nobody answered. So I also ask here, probably someone has an idea!
a) according to the service manual, the signal generator should display a 2 digit status code in the far right of the frequency display while the STATUS button is pushed. My generator shows something else: it has a 1, followed by a space, and then 00. 00 seems to be fine, but the manual doesn't tell anything about an additional leading status code, so I wonder whether this is actually code 100 (which doesn't exist) or whether it is code 1 AND code 00 (which wouldn't make any sense either). Probably someone can check with his 8663A?
b) I noticed that when I manually change the frequency from < 100MHz to >100MHz, there is a relay chattering inside the generator. No problem with that; output frequency and power seem to be OK. But when I do a sweep in this range, the relay does not chatter. Why? malfunction? later I realised that it does no longer chatter around 100MHz, but between <200MHz and >200MHz. I cannot reproduce exactly under which circumstances the relay becomes active at 100MHz or at 200MHz, but it is kind of strange. However, the output frequency and amplitude are fine. I am just wondering whether this looks like my signal generator is having some problem or whether this is just fine.
