Just acquired one with 8711A on panel but after booting it shows 8711B so I guess it's been upgraded. The first problem was that several of the rubber keypads were stuck under the panel and I was able to get them to pop out, ( I wonder if this was abuse by a disgruntled employee?). The second problem is that it doesn't always respond to button pushes more so with the soft keys. The AVG, CAL, and FORMAT key pads not seem to be protruding as much as the rest. Haven't had a chance to open it up but I wonder what kind of membrane matrix iOS under the panel and if it's fixable or replacements are available.? Is it a big job to get under the front panel for a look see? I also see there's a DIN plug on the back for an IBM PC keyboard and if I can find one can I control the unit with the keyboard before I have to tear into it?
Thanks
Hank WD5JFR Green Valley AZ
