1) The kit pages on your site, while showing all components quite neatly, don't really demonstrate the various ways you can configure all the parts. The pictures just look like a whole bunch of parts. It's not obvious to me which kit is appropriate, because I can't really see it in action. Some actual action pics of each kit would really help.
Agreed, the kit pages how a lot of parts. For each of the kit pages, there is a table on the page that shows the name and quantity of each part included in the kit. If you click on the part name, it will take you to that individual part and show some pictures of the part in action. But, we still need to show more parts in action - something we will work on.
2) (and this is more personal/subjective) I wonder if I would actually use the kit in practice, or if it will be more work than it's worth/take up more space than is practical. I have lots of various panavise bases and tops and for the most part they cover my PCB-holding needs well. I also have a cheap Aven PCB holder ( http://www.amazon.com/Aven-17010-Adjustable-Circuit-Holder/dp/B00Q2TTQEE/ ), but I almost never use it because of how high it holds the board. The awesome anodized parts of PCBGrip appeal to my nerd-self, but I fear the setup would be much too fiddly and I would be constantly adjusting it.
When I started building PCBs, I was building custom jigs made of various parts, including wood and springs. I could not find a setup to hold the PCB and be able to hold other things too (like hold through hole components upside down while I soldered). PCBGRIP is great at holding the PCB and 'something else'. PCBGRIP uses a open source aluminium extrusion (OpenBeam), which accepts standard 3mm hardware. That way, it is easy to attach what every you need to your setup, it addition to holding the PCB. The hinge assembly allows you to rotate the PCB 360 degrees. The PCB can be tilted. Also, the height of work can be adjusted, by raising or lowering the hinge assembly on the 10mm stainless rod. Here is an overview of the work height that can be accomplished
http://pcbgrip.com/blogs/blog/18208587-work-height-and-position. Here is a holder we designed to hold a Saleae logic analyzer, to give you an idea of how things can be attached to the OpenBeam:
The Saleae holder is available on Thingiverse here :
http://www.thingiverse.com/thing:735911
