Author Topic: Is my Rigol 1102 failing  (Read 1381 times)
Offline alan856Topic starter
« on: March 10, 2018, 02:24:16 pm »
Greets!  My faithful 1102 is dying. I've had it for maybe 5 years, and has been lightly used for Arduino projects.
Today, I turn it on, and both Channel  1 & 2 are on - and I can find no turn 2 off! When ever I press any buttons,
many are showing "function not available". Also Ch1 & Ch2 are always on and can't be turned off. I'm pretty sure
it is dying (just when I need it most) and either a new one trip to repair depot.
And it has no sweep and won't display square wave samp sig.
Look like a goner, right?   :-BROKE
Offline tooki
Re: Is my Rigol 1102 failing
« Reply #1 on: March 10, 2018, 02:42:32 pm »
I’m guessing another button is stuck on, causing spurious inputs (“ghosting”). Try wiggling each button (including rotary encoders). If that doesn’t help, i guess you could open it and clean the button contacts and perhaps check the interconnects (if the buttons are on a separate PCB; I don’t remember the internal construction of that model).
Offline StillTrying
  • Country: Broken Britain
« Reply #2 on: March 10, 2018, 02:44:28 pm »
Sounds like it could be in X-Y mode.  :-//
Offline tooki
« Reply #3 on: March 10, 2018, 02:49:45 pm »
Good call, that’s even more plausible than my explanation!
Offline StillTrying
« Reply #4 on: March 13, 2018, 03:02:52 pm »
"Look like a goner, right?   :-BROKE"
So.. did the OP get it unstuck/working?
Offline rhb
« Reply #5 on: March 14, 2018, 01:28:31 am »
The service manual is available online.  It's not much, but it does provide disassembly instructions.
Offline DC1MC
« Reply #6 on: March 14, 2018, 05:19:30 pm »
Just my 0.02EUR: Most likely is the NAND flash holding the firmware, if possible, while still booting try to do a (pseudo)update with the same software version and see if it improves the behavior.
 Good luck,
 DC1MC
