A little bit off topic, but if someone would like a logic analyzer that supports state mode in addition to timing mode, here is one to consider:
http://www.pctestinstruments.com/34 CHANNEL LA1034 LOGICPORT LOGIC ANALYZER
500MHz Timing-Mode (Internal Clock)
200MHz State-Mode (External Clock) Advanced Multi-Level Triggering
Real-Time Sample Compression
+6V to -6V Adjustable Logic Threshold
CAN, I2C, SPI, RS232, 1-Wire and more
Built-in 300MHz Frequency Counter
USB 1.1 and 2.0 Compatible
Sample buffer: 34 x 2048 samples
Maximum input: +/-40 volts DC, 15 volts peak-peak pulse amplitude
