Hello guys,
I was lucky and have got the opportunity to play a little with the LA104 analyser. Hard to say if it is worth the money with current firmware, but with the help of community it can become really very sophisticated laboratory equipment worth twice the money or even more. The company producing this unit released source code of their firmware, so it is quite easy to add there new features. You can consider it as development board with FPGA, ARM M3 CPU running at 60MHz, lcd display, 8 IO pins and USB connection. With a little effort you can run there any of your favourite arduino programs.
If you expect to get full featured laboratory grade logic analyser, you could be disappointed. It seems that it can be now used just to graphically review 4 digital signals with possibility of decoding UART or SPI. I am bit sad, because 4 bits is usually too little to do some serious analysis.
To sum it up:
Pros:
- partially open sourced (FPGA code was not still released)
- supports SPI/UART decoding
- trigger pattern
- 10nS sampling resolution
- 320x240 16bpp lcd display
- can run arduino snippets
- battery powered
- 8MB internal storage for whatever you want (more applications, signal snapshots, etc...)
- small portable design
- great for educational projects
- great for in field measurement
- powerful enough to control 2 axis CNC or play midi instrument
- IO pins could be expanded by external circuits, but at the expense of losing sampling speed
- if you can do some basic programming, you will love this unit
Cons:
- only 4 input channels (the other 4 pins are currently used for PWM/UART/SPI/I2C signal generation)
- takes some time to get used to the controls (only 2 rotary encoders and 4 buttons)
If you want to know more:
https://github.com/gabonator/LA104
