If it's powered by SMPS and has a standby rail for power ON it needs be at the point of entry.
That makes sense, the power is needed for the switch activate on the rest of the device.
I just put a linear power supply into my FeelTech FY6600 along with a C14 grounded outlet, a proper fuse and holder; the question popped into my head while wiring it. If the fuse blows and I can turn off the switch, I don't have to unplug it.
I decided that if the fuse is ahead of the cheap Chinese switch it may be of some advantage and I'd probably unplug it anyway if the fuse blew; that's how I wired it in any case.
