I don't think I've ever used my clamp meters for voltage readings before.
I won't be using this one for anything other than DC current, so it doesn't matter to me. I just opened it up because I thought some people here might be interested.
How does it go with current accuracy / resolution?
Much like the results Martin gets. It's finicky to get right. The zero button is a latch. That just doesn't make sense. You have to tun it off and back on before each reading.
As well as testing it on the bench, I tried it on 9 cars we have here. A couple of them have battery cables that are too thick for the clamp. I found the best accuracy was obtained by holding the meter right next to the cable I wanted to measure, zeroing the meter, and then clamping it on, keeping the angle the same as it was while zeroing it.
