Yeah, matching the socket will be the challenge. I had a look around Digikey and can't find anything with that matches. So I'll either do like you said and get wider, or simply take the contacts out of an old ISA socket and solder them down with the correct spacing to two boards, which I can bolt together using some plastic as spacers, effectively creating my own ghetto socket. (I've done this before, works great!)
In other news, I found an entire set of boards from a working pull for $30 on eBay! Of course I bought them; at worst I'll have a nice supply of spare parts, as I plan on fully restoring this to original condition and keeping it as a transfer standard.
I found a label on the side showing the original factory calibration:
This thing is 5 months (to the day) older than I am!
Here's a picture with the back panel open, showing the rectifier assembly (black cage in the center) and SCR relay (center right), main pass element (far right, large heatsink) and finally, several resistors with a small lightbulb underneath [which I assume is to heat them] (far left):
Then we have a view from the bottom of the unit, look at that huge ass transformer in the center (which has to weigh at least 30 of the total 50lbs of the unit):
That loomed wiring is really a work of art. (That's one reason I've been restoring old Power Designs supplies lately; so much great craftsmanship went into these older bits of test gear.)
Sent from my Smartphone
