Author Topic: Mastech MS8040 True RMS DMM Teardown  (Read 6637 times)
Online enut11Topic starter
  • Love building/modifying/restoring test equipment
« on: June 02, 2016, 03:13:28 am »
I needed a new DMM that I could leave on all day without worrying about battery life. I also wanted at least 5 digits and reasonable accuracy. Other wants (not needs) included temperature logging and and PC interface for data logging. Price budget was around $200AUD.
The MS8040 that I ended up buying has the following specs:
LCD Count: 22000
DC range: 200mV to 1000V, 0.05%
AC range: 200mV to 750V, 0.5% TRMS
Ohms range: 200 to 200M, 0.1% up to 2Mohm
Temperature: -30C to 1300C!, 1%
Other functions include DCA, ACA, Capacitance, Frequency and the ability to be used with an AC/DC clamp meter.
Bundled items include test leads, power cord, RS232 cable, Temp leads and Cap/Temp adapter.
This unit has a large back-lit LCD display which clearly shows which function you have selected. It also includes a useful analog display.
Because it has dual power (9v battery or 6 AAA cells or 240VAC) the back-light only stays on for less than 1 min. I never intend to use it as a portable DMM so I wired a permanent fix for the back-light.
https://www.eevblog.com/forum/testgear/mastech-ms8040-bench-dmm-back-light-problem/msg953142/#msg953142
« Last Edit: June 02, 2016, 03:29:28 am by enut11 »
an electronics nut from wayback...
The following users thanked this post: square circuit
Re: Mastech MS8040 True RMS DMM Teardown
« Reply #1 on: June 02, 2016, 03:18:14 am »
It did not take long for my curiosity to take over and I had it apart on my bench. Below are some shots of the internals...
« Reply #2 on: June 02, 2016, 03:23:54 am »
More pictures including power supply. At the rear of the box is where the 9v or 6x AAA cells go if you want portable power. I simply power mine with 240VAC.
« Reply #3 on: June 02, 2016, 03:25:05 am »
I needed a new DMM that........
AC range: 200mV to 7500V, 0.5% TRMS
Really?  :o
Avid Rabid Hobbyist
« Reply #4 on: June 02, 2016, 03:30:18 am »
Oops, I meant to type 750 VAC...
« Reply #5 on: June 02, 2016, 03:41:35 am »
The Mastech MS8040 is easy to use. All functions are clearly labeled and easy to interpret. My only complaint is that the 12 position rotary knob is not smooth to operate. Internally, it is simply a nylon sprung "ball" locking into a V groove with no lubrication.
The PC interface relies on RS232 connectivity although I have yet to try it. I am told that it works with an XP system. I have Win 10 so will try a RS232 to USB adapter.
Offline Hydrawerk
« Reply #6 on: June 03, 2016, 01:33:20 am »
It is CAT II 1000V but has only 250V fuses.  :(
The following users thanked this post: enut11
« Reply #7 on: June 04, 2016, 01:46:51 am »
Good point on the fuse rating but not a problem for me. In 40 years of electronics the highest voltages I have measured were around 100vDC and 250vAC.
However, if an instrument is rated for 1000VDC and 750VAC, it should be properly designed.
Thanks, enut11
Offline grantb5
« Reply #8 on: September 04, 2018, 10:09:26 pm »
Dumb question ... I've only ever used a handheld DMM.  Is the COM banana plug electrically connected to the AC power input? Pretty sure my soldering iron tip and oscilloscope ground are all connected.  Just worried about what I can and cannot probe without investing in an isolation transformer or something.
Offline Vgkid
« Reply #9 on: September 04, 2018, 10:31:46 pm »
The positive and common jack are connected to each other through a 10Megohm resistor. You can probe voltages until the max ratings.
Edit.
Multimeters are differential , you won't hurt anything with the ground lead.
« Last Edit: September 04, 2018, 10:36:32 pm by Vgkid »
Offline grantb5
« Reply #10 on: September 06, 2018, 03:19:41 pm »
I meant between the COM banana jack and the 3rd prong on the mains AC cable in.  I can buzz it out if I can find a portable meter around here someplace.  With a portable DMM I can measure a voltage across an arbitrary resistor in a live circuit without worrying that I'm grounding one end of said resistor. That's my concern I guess. Or maybe I didn't comprehend your answer...
Offline Vgkid
« Reply #11 on: September 06, 2018, 03:31:44 pm »
Ground(earth) is not connected to the meters common input terminal.
The following users thanked this post: grantb5
