I just took delivery of a Maynuo M9812 (cheaper than the M9712 this week). On powering it up, I got quite an audible switching sound/hum. A visual check of the PCB showed nothing amiss and I couldn't pinpoint the source or an offending MSOFET in particular. Both heat sinks were humming when tested with a dowel. Display reading are OK, although the voltage is a bit off which I will recal. After discharging an SLA, the device is now much quieter on no-load, but there is still quiet hum. I've had a similar unit in the past that was quiet until loaded. Is this normal for this model, or should I be testing the drivers/MOSFETS and refastening everything?
