As Joe has repeated many times, and has even changed the subject of his thread to avoid misconceptions, his tests are not an indication of any meter's ability to pass their CAT ratings. The tests are to show the robustness of the meters to function after abuse, misuse, and every day errors. The tests can give an indication as to how well these meters might pass a proper CAT test or how well they might protect the user, but that is not his intent.
A generic UT61E should not be considered safe for mains use. Its CAT rating is a lie. The GS version can be trusted for its CAT rating. The UT139C is much safer but it is not a given that it is fully compliant with its CAT ratings.
The Fluke 101 would be a good choice, as would anything with proper third party testing and certification. CE markings mean nothing. Look for UL, CSA, TUV, GS etc.
Other good choices: Anything Fluke, anything Keysight, most Amprobe, Extech MM series, anything Brymen, Hioki, Yokogawa.
The second someone tells you to ignore safety rules and don't worry, worry. The ratings and rules have been implemented for reasons. They are from experience of people getting hurt and/or killed, or damaging equipment. Yes, some rules are to protect the stupid from themselves, but they are also there to protect the smart from themselves. We all forget things and humans tend to make errors and take short cuts when they think it "won't be a problem this one time". If you are inexperienced, the last thing you want to do is flaunt the safety rules. People do die from not knowing.
