EDIT: 7/21/22 - There doesn't seem to be a problem with the Function Generator, after all. The problem seems to be operator error. So, I am marking this thread as "Closed" and starting a new, separate thread in which to ask operational questions.
RE: Rigol DG822 Function Generator
Serial # DG8A204201741
FIRMWARE #00.01.08.00.01
Hobbyist level skills, with nice lab equipment that is smarter than I am.
The Problem – First time trying to use the Sweep Function
When I select the Sweep output function, it illuminates. However, the Continuous output function remains illuminated and the unit continuously outputs the lowest frequency of the sweep range. (I am sweeping a sine wave from 20 to 20KHz, so 20Hz is being output, continuously.) This continuous output trips the trigger on my oscilloscope, so I can't capture the single sweep. When I press the trigger button, on the FG822, the 20-20KHz sweep is output, but the unit immediately reverts to outputting the 20Hz frequency, continuously.
I have upgraded the firmware to the most current version (00.02.06.01.) However, this did not solve the problem, or change the errant behavior.
So, I am thinking that this is a lingering bug, or that the manual does not fully explain the Sweep Function setting protocol.
Here’s my Settings Protocol
- Sweep Function
- Sign Wave
- 20Hz to 20KHz
-1Vpp
- Linear
- Manual
- Markers = Off. I have not set any Markers, because I did not think that they were in play.
Are Markers the key? Or, is there some other step that I am missing, like an “enter” button that captures the new settings and I am not seeing it to push it?
I have put in two calls to Rigol and left word for a callback on their automated voice system. As yet, I have not heard from them.
Suggestions, please and thank you.
