Tek runs Java VM on their scope? That could be slow and irresponsive. Seems like the good deal for that MSO3014 goes away.
The TEK 3000 series does not run windows, and the interface is quite snappy. It's a real fine scope.
I'll do a bit of research on this one, I can get a good deal, it has 16 digital, 4 analog, LAN, video out; pretty much anything I want.
A close call would be the Agilent DSOX2014A but it's 2000X series, no digital inputs and every option costs a small fortune? Please correct me if I am wrong.
Those are all within my budget, took me a bit to build the list
Brand Model Price Channels BW Refresh LCD Resolution Bandwidth Sample Memory
Rigol 2072A 750 2 20 Mhz 50000 8 800 x 480 70 Mhz 2 GS 14 Mpts USB Host LAN 0.5v / div
Rigol 2102A 1000 2 20 Mhz 50000 8 800 x 480 200 Mhz 2 GS 14 Mpts USB Host LAN 0.5v / div
Rigol 2022A 1400 2 100 Mhz 50000 8 800 x 480 200 Mhz 2 GS 14 Mpts USB Host LAN 0.5v / div
Rigol 4014 2000 4 20 Mhz 110000 9 800 x 480 100 Mhz 4 GS 140 Mpts USB Host LAN VGA Intf 2mv /div
Rigol 4024 2400 4 20/100 Mhz 110000 9 800 x 480 200 Mhz 4 GS 140 Mpts USB Host LAN VGA Intf 2mv /div
Tektronix MSO 3014 1700 4 + 16 100 Mhz 50000 9 800 x 480 100 Mhz 2.5 GS 5 Mpts USB Host LAN VGA Intf
Agilent DSOX 2012A 1000 2 50000 8.5 800 x 480 100 Mhz 2 GS 0.1 Mpts USB Host
Agilent DSOX 2014A 1600 4
Agilent MSOX 2012A 1600 2 + 16 50000 8.5 800 x 480 100 Mhz 2 GS 0.1 Mpts USB Host
Agilent DSOX 3032A 2600 2 1000000 8.5 800 x 480 350 Mhz 4 GS 2 Mpts USB Host
