Yeah, that'd be a good choice. What I once did for a large rack was put two thick pipes along the staircase, screw them in place, put a wood board on top, put the rack on its side on the board, and pull the entire thing up the staircase with a pulley with a braking system.
Creative.
These are all separate pieces. Prior to my smashed arm and blown discs in my neck and spine, this would have been a non-issue. There are about 25 stairs in the longest run and I think you gave me an idea about just running some 2x4's down on top the stairs. The stairs are outside so a few screws won't be noticed. I'll also look into the stair climbing hand truck. I saw something like that once.
Right now I'm leaning towards grabbing some day labor for three or four hours = $60 to $80 or so. Maybe I can combine this with putting my OCFD antenna back up.
It would be nice if there was a lift that had something like forks in the front that you could crank-up, lifting equipment even with the units and then pushed right into the rack. Balance would be an issue. But of course, I dreaming and it would have to work in a crowded 14' x 16' room with a thickly padded rug.
There's something to be said for new, modern equipment opposed to these boatanchors, some of which have moved into the antique phase.
Anyway, I knew it was a long shot and thanks for the ideas.
~Jerry
