Upgrade kit?
I started out by watching a few relevant videos on youtube. This Youtube video should cover everything you need for now.
One thing I've experienced that the drawer is often a little colder than the air inside, and may prevent the solder paste to melt properly because it's pulling away the heat from the board you're reflowing. I'm using some simple metal spacers, but a simple metal mesh will work too.
