Author Topic: MSO1104z hacking possible?  (Read 4107 times)
Offline Boscoe
« on: February 07, 2016, 10:57:10 pm »
I need to hack my MSO1104z scope for the I2C decode option - might as well have all the others too!
I'm unable to do it atm. rigol.3owl.com is down and the other one (gotroot) only gives me an invalid code. Is there any other way of doing this? Is my scope compatible because it's mixed signal?
Thanks
Offline kripton2035
Re: MSO1104z hacking possible?
« Reply #1 on: February 07, 2016, 11:36:07 pm »
Offline CustomEngineerer
« Reply #2 on: February 08, 2016, 04:13:12 am »
Maybe stupid question but are you using the MSO1000Z patched version of rigup (rigup-0.4.1-mso1000z.zip)? If not you can find it on gotroot.ca.
Offline Boscoe
« Reply #3 on: February 08, 2016, 04:41:41 am »
I don't know what this is. Could you give me some more info?
Offline kripton2035
« Reply #4 on: February 08, 2016, 06:45:23 am »
Offline Boscoe
« Reply #5 on: February 08, 2016, 07:08:29 am »
he means here : http://gotroot.ca/rigol/riglol-103d/
Yes, this doesn't work for me. It says it's invalid and I've tried a few unlock options - all didn't work.
« Reply #6 on: February 08, 2016, 07:23:35 am »
No, I was referring to http://gotroot.ca/rigol/rigup-0.4.1-mso1000z.zip .
Its a version of the rigup program that has been patched to work with MSO1000Z memory dump. The link you provided doesn't list MSO1000Z as an option so I would it assume it doesn't work for those scopes, but since I haven't used it I could be wrong.
Offline Boscoe
« Reply #7 on: February 08, 2016, 07:21:26 pm »
Are there any instructions on how to use this? The readme just tells you how you should not ask questions and read but it's doesn't provide any information!
« Reply #8 on: February 08, 2016, 07:30:22 pm »
« Last Edit: February 08, 2016, 07:32:44 pm by CustomEngineerer »
