Author Topic: Multimeter spreadsheet (80 manufacturers and over 400 meters listed)  (Read 825136 times)
hsetlik and 1 Guest are viewing this topic.
Offline WytnuclsTopic starter
Re: Multimeter spreadsheet
« Reply #25 on: February 26, 2014, 08:07:58 pm »
Maybe a simple index of whether the meters generally meet their spec...
I think this would be great, if say, you don't recognize a Fluke from a whatever... Some indication of general "trustworthiness" would be helpful since I only recognize one to two brands.
I just spent some time doing my home style "calibration". I bought a DMM check and in short, my 30 year old Fluke 8050A's spec'd to be about 0.1% accurate, look to be more like 0.01% accurate after 30 years. Some cheap UEI meters are much newer, and at the edge or just outside their specs of 1%.
Most of these meters are from reputable companies. Some of them come standard with calibration certificates or as an extra option.
You can generally work on price. The few meters from less well known companies, selling for less than 150$, are the most likely to drift over long periods, as they tend to use cheaper components.
Among those, I can only vouch for the UT71 series, two of which I test regularly. My 61E, unfortunately, didn't fare so well.
Most companies still recommend an annual calibration for their meters.
New file: A few more Fluke meters added to the list.
« Last Edit: February 26, 2014, 08:35:31 pm by Wytnucls »
The following users thanked this post: Marco1971
Offline Fsck
  • sleep deprived
« Reply #26 on: February 26, 2014, 08:51:26 pm »
Great work , thanks !  :-+
Although there are many others more, I think these extra specifications are interesting aspect as well, suggesting to add 2 more columns for "Operating" Temperature and Altitude if applicable or stated by the manufacturer.
These are for Fluke :
87 V, 287 and 289 :
Operating Temperature : -20 °C to 55 °C
Operating altitude :
87 V : 2000 m
287 & 289 : 3000 m
Again, just a suggestion.
and to the fact that accuracy is not guaranteed outside of 18-28C
"This is a one line proof...if we start sufficiently far to the left."
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #27 on: February 27, 2014, 01:52:13 am »
Wytnucls, this is a great list!
One remark: the Fluke 179 measures frequencies up to 100kHz in both the VAC and VDC, therefore I have the impression its bandwidth is not 1kHz (despite the manual says the bargraph can't be trusted above 1kHz). Maybe I am wrong?
Also, not much love for the BM857A... Possibly due to price/features?
And what about the DT-830?  :o
« Reply #28 on: February 27, 2014, 02:13:33 am »
I'll do the CEM meters shortly.
Bandwidth is quoted for TRMS accuracy, usually until 1 dB of attenuation. It has nothing to do with the frequency counter.
For instance:
New file being loaded with older Fluke and Yokogawa meters.
« Last Edit: February 27, 2014, 02:36:48 am by Wytnucls »
Offline rsjsouza
  • Eternally curious
« Reply #29 on: February 27, 2014, 11:17:17 am »
Thanks! Learned something today.
Offline Galenbo
« Reply #30 on: February 27, 2014, 12:41:16 pm »
Nice list, 2 things can be added:
* (configurable) auto off
* dial knob with only off-volt-ohm-amp or with 20+positions (there is some correlation with autorange)
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline Marvin
  • Country: ee
« Reply #31 on: February 27, 2014, 02:28:22 pm »
Well one thing that you don't have is manufacturer specified battery running time - as this is handheld list some of the models have really awful running times that I weigh in when comparing models.
Offline SoundTech-LG
« Reply #32 on: February 27, 2014, 05:04:42 pm »
Great!!!
I started a little Fluke file.
Here's what I got so far using your spreadsheet. double check my entries. The accuracy, I am not sure how you entered that.
« Last Edit: February 27, 2014, 05:08:43 pm by SoundTech-LG »
Offline Nermash
« Reply #33 on: February 27, 2014, 05:14:39 pm »
Fluke 115 does not have LowZ mode and it does not have proper jack detection. It only displays "Lead" warningn when you turn the switch to current measurement.
« Reply #34 on: February 27, 2014, 05:44:26 pm »
Good catch on LowZ. At least it gives you visual warning on the current leads. Maybe a separate column for that?
« Reply #35 on: February 27, 2014, 06:43:50 pm »
It has a LoZ feature for capacitance measurement. The feature may not work for ghost voltage detection though. Fluke still calls it LoZ mode.
Lead warning is just that, but it is an attempt at better safety on the current jacks.
« Last Edit: February 27, 2014, 06:46:21 pm by Wytnucls »
« Reply #36 on: February 27, 2014, 06:47:44 pm »
Great!!!
I limit the file to meters with a resolution of at least 6000.
« Reply #37 on: February 27, 2014, 06:54:41 pm »
Just about all meters in the list have an auto-off feature, except for the 61E. Configurable is nice, but not a major deal breaker.
I have to limit the number of columns to the most relevant information for readability. It is not meant to list all the meter features.
« Reply #38 on: February 28, 2014, 12:30:18 pm »
Latest file uploaded. Added UEI, Ideal, Prova and BK Precision meters and some extra meter information.
« Last Edit: February 28, 2014, 09:19:46 pm by Wytnucls »
« Reply #39 on: March 04, 2014, 02:14:45 am »
File updated with Mastech, Victor, Vichy and Extech multimeters.
Online BravoV
  • +++ ATH1
« Reply #40 on: March 04, 2014, 06:01:42 am »
I thought when people talking about DMM's LoZ input "mostly" is for voltage measurement ?
Putting it at LoZ column probably may misleads readers, maybe another extra column for "LoZ Cap" ?
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #41 on: March 04, 2014, 06:03:53 am »
This is a really impressive undertaking Wyt. I will find this extensively useful.
Sent from my EVO using Tapatalk
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
« Reply #42 on: March 05, 2014, 11:01:22 am »
I can't add too many columns. I will add a note to mark the difference.
« Reply #43 on: March 06, 2014, 10:32:46 am »
New file uploaded with a few extra meters and duty cycle feature added.
« Reply #44 on: March 08, 2014, 03:49:14 am »
New files with Chauvin Arnoux Metrix multimeters added.
« Reply #45 on: March 10, 2014, 08:05:16 am »
New list with the true RMS V&A multimeters.
http://www.mastech.com.cn/
The Shanghai company seems to have split up from Mastech.
They make a lot of advanced meters, but the quality of assembly was rather shaky in the past. Hopefully things have improved now. To be confirmed.
Offline ttp
« Reply #46 on: March 10, 2014, 09:01:07 am »
Great work! One tiny error I've noticed - Brymen BM867 does have 4-20mA measurement.
« Reply #47 on: March 10, 2014, 12:17:13 pm »
Quite right. Will be updated in the next upload. Thanks.
Offline Lunasix
« Reply #48 on: March 10, 2014, 05:56:41 pm »
Great works !
A small precision : Metrahit 28S (and some others I think) can be connected to PT100, PT1000, K and J thermocouples.
« Reply #49 on: March 11, 2014, 01:55:34 am »
Yes, 28S and 29S can handle K and J type probes.
18S, 25S and 26S Pt100/1000 only
The listed current Gossen meters can do Pt100/1000 and K type.
Only the 30M has the 4 wire temperature measurement capability.
Will update the file shortly.
