Am I correct assuming the key generation scheme is (still) unknown for the 80K series ?? (and those using the same firmware...)
Quote from: darkstar49 on February 04, 2018, 05:54:20 pmAm I correct assuming the key generation scheme is (still) unknown for the 80K series ?? (and those using the same firmware...)I think I know the key generation scheme for all Infiniium scopes that use the 5.71 firmware and that includes the 80k series. I've generated numerous keys for two different 80k scopes. I've also generated keys for other Agilent gear. I don't think it's a very secure system so I don't think this is a difficult or demanding task. I'm from an RF background rather than software (and I'm quite old!) and I managed it? The DSOX2000 and 3000 hacking thread is about 5 years old and I think they are still hacking these scopes via crude and dodgy patches. I've never used one of these scopes or seen the licensing scheme they use but I expected by now that someone would have progressed to a more elegant/safer solution via keycodes?I think you could also hack the 80k series scopes with a SW patch but it is a bit of a crude and messy way to do it.
G0HZU,Can you share any more details on your methods? I have a 3K series i would like to liberate and would much prefer key methods over command argument mods.I understand if not.(Cant PM you, so.... :-)Thank you,-j
Quote from: jasonbrent on March 21, 2018, 12:55:38 pmG0HZU,Can you share any more details on your methods? I have a 3K series i would like to liberate and would much prefer key methods over command argument mods.I understand if not.(Cant PM you, so.... :-)Thank you,-jHelloI can give you all information you needSent from my SM-N950F using Tapatalk
