Hello,
I'm kind of a noob so I'm sure I'm just doing something stupid here. I keep getting vac readings on my 1.21gw when there shouldn't be anything. They tend to drop off over time. I was just playing with the meter connected to my crappy 30v bench power supply (pevono ps305H). I'm pretty sure it's the meter that has the problem because I do the same test with my no-name meter and get 0vac also with my fluke 117 I get 0vac. I don't think it's within the range of my crappy meter, but it should be in range for the fluke. I don't have a scope to connect to the ps. I did add two 1000μF filter caps to the power supply when I got it.
I've included a screenshot from the 121gw app that shows the reading over time.
http://www.kellyphotos.org/ForumPics/eevblog/121gv%20ac%20voltage.jpgSeems odd to me. Am I making some noob mistake?
I get similar behavior from it if the probes aren't connected at all.
Firmware: 1.57
I just got the meter today.
