but.. why 32 channels?
At least on Pico X+16 MSO you run out of all digitals if use 16x1bit as 16bit ADC input to gain 16bit "virtual channel". With 32 would still have 16 left... Of course if such thing even possible on Tek. As for analog channels - indeed run out of them in no time when attach to some motor... +use digitals to listen for 24V PLC signaling. So think more the merrier
Besides micros and HF signaling there is whole world full of actual machinery that does actual stuff. But if its 2GHz... hmm... Tweak 3ph motor plus wireless signaling instead of 24V at the same time maybe
In that case they should install enough memory so it could run at least 5GSa/s in ~100ms/ timebase.
