In the description is there a mistake?
"Do NOT input voltage exceeds 36V DC or 25V AC when you are at the setting of measuring current. " or doesn't handle 250V volt on the Amps scale for example measuring current in DUT on a mains circuit.... That would give some burned multimeters.... if exceding this voltages It is also written in the manual...
For acessories thats a good bargain indeed
Sorry it is not written in the manual that warning but another:
"When the voltage to be measured exceeds 36V
DC or 25V AC, the operator shall be careful
enough to avoid electric shock."
Doesn't refer about maximum allowed / rated voltage on current measurement. So are added notes
