Edit - version 7.11 has now replaced version 7.10
Download here:
http://www.keysight.com/main/software.jspx?ckey=2573488&lc=eng&cc=CA&nid=-11143.0.00&id=2573488Release notes:
http://www.keysight.com/main/redirector.jspx?action=ref&nid=-11143.0.00&lc=eng&cc=CA&ckey=2573486&cname=EDITORIAL&nfr=-11143.0.00It looks like the new firmware Daniel from Keysight mentioned during scopemonth has been released for the 3000T and 4000 series scopes.
The firmware version has changed from 4.08 to 7.10 (quite the odd change).
New features added:
–Added Frequency Response Analyzer option (DSOXT3FRA).
–Added Manchester/NRZ serial decode option (DSOXT3NRZ).
Enhancements:
–The measurement system has been updated to provide more flexibility to support new measurements with more complex configurations. Some installed measurements will not be recallable if the setup (.scp) file was created with firmware prior to version 7.10.
–Users can now pick specific edges to be used by the Delay measurement.
–Bartlett is now supported as an FFT window choice.
–The UART serial decode now supports baud rates to 12Mbits/s.
–DVM and training signals are now standard features.
–Added random trigger holdoff feature.
–Added support to the NFC option for NFC-F reverse polarity triggering.
–Added Channel Power, Occupied Bandwidth, Adjacent Power Ratio, and Total Harmonic Distortion measurements
Bug Fixes:
–Fixed an issue where in certain circumstances the Serial Lister would not properly display some UART data.
–Fixed an issue where in certain circumstances the Peak-Peak measurement was incorrect.
