0 Members and 12 Guests are viewing this topic.
The little yellow plastic tings that come on the end of the probes, what purpose do they serve?Also are they supposed to stay on the end of the probe?Mine keep falling off (1st scope, so this is all a bit new, apologies if it's a silly question)
Quote from: v81 on March 26, 2015, 07:04:40 amThe little yellow plastic tings that come on the end of the probes, what purpose do they serve?Also are they supposed to stay on the end of the probe?Mine keep falling off (1st scope, so this is all a bit new, apologies if it's a silly question)See this thread:https://www.eevblog.com/forum/testgear/retractable-hook-tip-on-rigol-ds1054z-scope-doesn't-stay-on-its-probe-!/Read it all.
Quote from: tautech on March 26, 2015, 07:28:35 amQuote from: v81 on March 26, 2015, 07:04:40 amThe little yellow plastic tings that come on the end of the probes, what purpose do they serve?Also are they supposed to stay on the end of the probe?Mine keep falling off (1st scope, so this is all a bit new, apologies if it's a silly question)See this thread:https://www.eevblog.com/forum/testgear/retractable-hook-tip-on-rigol-ds1054z-scope-doesn't-stay-on-its-probe-!/Read it all. Read through it and watched the video too, all good stuff.There was a suggestion that the yellow part was to help with the measuring of pins on IC's.But i never found an answer as to why it won't stay attached.The hooks attach nicely, no problem there, but the yellow pieces will not stay on regardless of how hard i push them on.Still looking for an answer.If i missed it would you point me directly to what i'm looking for?
The ... yellow pieces will not stay on regardless of how hard i push them on.
Quote from: v81 on March 26, 2015, 11:07:41 amThe ... yellow pieces will not stay on regardless of how hard i push them on.FWIW, they're hit & miss IME (I've 2 that will stay on, and the other 2 that won't without help).Perhaps try a bit of tape on the inside of the yellow pieces, and see if that helps.
Quote from: nanofrog on March 26, 2015, 11:29:23 amQuote from: v81 on March 26, 2015, 11:07:41 amThe ... yellow pieces will not stay on regardless of how hard i push them on.FWIW, they're hit & miss IME (I've 2 that will stay on, and the other 2 that won't without help).Perhaps try a bit of tape on the inside of the yellow pieces, and see if that helps. You would be real happy if they fell off when probing a densly populated high powered circuit and allowed the GND ring to contact a component lead. BANG shit pants, DUT, scope and probe.
Do not use DSFR or DSBA - 500uV Vertical as this does not work and causes problems with the scope.
That's great plazma!!! Mines suppose to ship tomorrow from Tequipment, crossing my fingers Thanks for sharing the results on the unlock, looking foreword to doing the same!!
Quote from: Lightages on March 20, 2015, 03:10:04 pmDo not use DSFR or DSBA - 500uV Vertical as this does not work and causes problems with the scope.Just to clarify - enabling itself causes problems? Or only using 500uV doesn't work.
Quote from: dewalt58 on April 01, 2015, 12:07:24 amThat's great plazma!!! Mines suppose to ship tomorrow from Tequipment, crossing my fingers Thanks for sharing the results on the unlock, looking foreword to doing the same!!Mine also. Here's to hoping it's not an April Fool's joke.
Quote from: arekm on April 01, 2015, 01:04:00 pmQuote from: Lightages on March 20, 2015, 03:10:04 pmDo not use DSFR or DSBA - 500uV Vertical as this does not work and causes problems with the scope.Just to clarify - enabling itself causes problems? Or only using 500uV doesn't work.As far as I know, as I have not tried it myself, it does not work AND causes other problems too. I could be wrong.
The probes are quite low quality. None of them kept the yellow cap in place. The 1x position is loose and sometimes causes noise.Luckily I have Agilent 500MHz probes coming.
Quote from: plazma on March 31, 2015, 11:04:02 amThe probes are quite low quality. None of them kept the yellow cap in place. The 1x position is loose and sometimes causes noise.Luckily I have Agilent 500MHz probes coming.You really can't expect Agilent quality in a $400 4-ch oscilloscope. And 500MHz Agilent probes are close to $100ea used on ebay anyway.Dave did a video on the RP2200 probes and found them adequateIf you remember please do a comparison between the RP2200 and the Agilent probes.I am curious as to how much noise is normal. There is a thread here that looks into this issue.
Is there a simple way to disable already enabled 500uV mode? Or the only way is to uninstall all and then put new code again?
