Flyinghacker, once you have the unit it will be easy to separate the AC power input from the voltage measuring connection on the board, giving you a unit with a common wire for power and sense. Then you connect power ( the capacitor) to the input AC, and the sense resistor connection to the variac output with the black probably being common.
