Analog Triggers are going to be part of the release, yes.
Also, real time view is on the way, but won't make it into the release. Vote it up!
http://ideas.saleae.comAnd no, the new Logic is not exactly an oscilloscope replacement. We *may* be thinking about doing that later.
Here's what you can not do with Logic's analog capability:High Voltages
Really small signals (<100mV) at high resolution
Really fast analog signals (over the rated bandwidth, which is 600kHz, 1MHz, or 5MHz depending on model)
Measure signal integrity on fast digital edges
RF
Eye Diagram
Here's what you can do:All low-medium bandwidth, low-voltage analog
Analog sensors
DAC/ADC/PWM->Analog
Op-amp circuits, classic analog circuits
Data logging
Power rail monitoring
Audio
Control systems
etc.
I've probably left a few things out, of both sides of the ledger. Let me know!
-Joe (Saleae Co-Founder)
