hello,
can some one help me.
the last time i have making a lot of tests with my ssa3021 hacked equipment.
I have see a strange behavior, are the persons who can simulate it so i will know if it is a hardware problem or a bug into the software
span: 50Khz
BW: auto =300Hrz
detect: All tested = same
trace: All tested = same
Preamp on or out = same
can some one do the same test to confirm if it is a hard or software fault or the man between the chair and the test equipment
If you search forum this is also previously been on the board.
Using some other settings and signal you can find more "noise steps" just like in Keysight image 3.3. Where is "noise floor after autoranging".
With your settings it is possible also turn it from FFT to normal (slow) sweep and this phenomenon disappear
I have seen this phenomenon long time ago (when SSA was just published and I get one quite early) and it is Perhaps something like this until proven otherwise:
Keysight (Spectrum Analysis Basics – Application Note 150, page 38) :
Figure 3-3 illustrates the sweeping behavior of the X-Series analyzers. The single-pole prefilter allows the
gain to be turned up high when the analyzer is tuned far from the carrier. As the carrier gets closer, the gain falls and the ADC quantization noise rises. The noise level will depend on the signal level frequency separation from the carrier, so it looks like a step-shaped phase noise. However, phase noise is different from this autoranging noise. Phase noise cannot be avoided in a spectrum analyzer. However, reducing the prefilter width can reduce autoranging noise at most frequency offsets from the carrier. Since the prefilter width is approximately 2.5 times the RBW, reducing the RBW reduces the autoranging noise.
Figure 3-3
