Author Topic: New TRMS Uni-T UT139C DMM is available now  (Read 144306 times)
Offline WytnuclsTopic starter
« on: July 28, 2013, 08:43:25 pm »
The new 6000 count UT139C DMM is now coming to market. It felt pretty well built, when I handled a sample two months ago, before its official release.
It seems reasonably priced too, for a TRMS meter with temperature measurement,a backlit LCD, NCV and optional clamp meter connection. It sells for about 50$ plus delivery cost on eBay (free delivery for the US).
At first glance, it looks like at least one HRC fuse is accessible from the 2 AA battery compartment. It is marked as CAT III 600V.
http://www.ebay.com/itm/UNI-T-UT139C-True-RMS-Digital-Multimeters-AC-DC-with-Temperature-Auto-Range-/181179994103?pt=LH_DefaultDomain_0&hash=item2a2f2b4ff7
« Last Edit: July 28, 2013, 09:29:37 pm by Wytnucls »
Offline edavid
Re: New TRMS Uni-T UT139C DMM is available now
« Reply #1 on: July 28, 2013, 08:50:31 pm »
I don't get it, why would you buy this instead of a UT61E?
Offline Monkeh
« Reply #2 on: July 28, 2013, 08:53:30 pm »
Temperature, clamp, backlight, NCV...
Counts aren't everything.
« Reply #3 on: July 28, 2013, 09:28:39 pm »
It also has VFC (Variable Frequency something?), Max/Min, auto power off, 3V diode test and possibly, proper input protection.
The rubber holster looks like it is removable.
« Last Edit: July 28, 2013, 09:35:18 pm by Wytnucls »
Offline BillyD
  • Country: ie
« Reply #4 on: July 28, 2013, 09:48:55 pm »
what clamp does it have? A current clamp?
Offline Lightages
  • Canadian po
« Reply #5 on: July 28, 2013, 09:49:20 pm »
The VFC function is basically a low pass filter to to remove noise caused by variable frequency motors/drives. It they took input protection seriously this time this would be a nice meter for the money. If they skimped and lied bout the rating again then this would be a potential bomb ready to go off in your hand.
« Reply #6 on: July 28, 2013, 10:04:49 pm »
I think it is compatible with the new UT221 and UT222 clamp meters, both TRMS AC and DC.
I'm not sure if they are available yet.
« Last Edit: July 28, 2013, 10:17:42 pm by Wytnucls »
« Reply #7 on: July 28, 2013, 10:26:01 pm »
There is hope, look at the picture ;)
Offline chibiace
« Reply #8 on: July 28, 2013, 10:55:32 pm »
are you sure thats a clamp icon on the voltage jack.
He Who Controls The Spice Controls The Universe
Offline Monkeh
« Reply #9 on: July 28, 2013, 11:02:08 pm »
Yes. It supports an external clamp with a 60A range, 10mV/A.
Offline true
  • INTERNET
« Reply #10 on: July 28, 2013, 11:57:22 pm »
If it's like the UT136 the NCV is 220V only. Need to find a manual...
Offline Monkeh
« Reply #11 on: July 29, 2013, 12:13:21 am »
Not their fault certain countries are behind the times.
Offline true
  • INTERNET
« Reply #12 on: July 29, 2013, 12:15:11 am »
Thanks for being helpful and posting the manual.
The meter I keep in my work bag is sensitive starting at 24V, but does trigger below that so in addition to outlets and power cords it's handy for quick checks to see if alarm and lighting panels are powered.
« Last Edit: July 29, 2013, 12:16:56 am by true »
Offline Monkeh
« Reply #13 on: July 29, 2013, 12:15:45 am »
I'm sorry, but I don't speak Chinese. Perhaps you'd like to go have a look?
I think we can reasonably expect it to be set for 230V.
Offline true
  • INTERNET
« Reply #14 on: July 29, 2013, 12:18:41 am »
Why? As I wrote above, it's possible to have a wider range than just line voltage. Additionally, the basic meter or stick NCV that trigger at ~100V will typically also trigger at higher voltages.
Offline Monkeh
« Reply #15 on: July 29, 2013, 12:20:18 am »
Trigger at higher levels, yes, and be violently oversensitive around lower voltages and coupled voltages in countries which don't use 120V distribution.
Offline true
  • INTERNET
« Reply #16 on: July 29, 2013, 12:32:33 am »
I really don't know why you want to argue this so much, it's like you feel personally attacked by this or something. Over a feature to quickly check if power is present on a power line or outlet. Sorry for upsetting you so strongly over such a simple question; I didn't know there would be such animosity when the possibility of voltages lower than 230V are brought to discussions.
I'll just wait for someone who buys one to post what the manual says.
Offline Monkeh
« Reply #17 on: July 29, 2013, 12:38:10 am »
Not so much..
My sincerest apologies for offending you with a joke.
Offline don.r
« Reply #18 on: July 29, 2013, 01:32:49 am »
Given that the UT136D only does 230V for NCV, its most likely true here as well. Remains to be confirmed, however.
Offline true
  • INTERNET
« Reply #19 on: July 29, 2013, 01:44:29 am »
Yeah, that is what I originally wrote... :( I am concerned because for what I do it would be helpful. My PM55A works fine but takes a while to "boot" :(
Offline don.r
« Reply #20 on: July 29, 2013, 02:19:56 am »
Ooops... must have skipped past that bit. Sorry. It would have been good, even if they offered a D or E model with 120V NCV instead of 220V.
« Reply #21 on: July 29, 2013, 05:31:21 am »
NCV is good for the States too on this one; it triggers at any voltage above 100V RMS.
« Last Edit: July 29, 2013, 05:35:52 am by Wytnucls »
Offline Electro Fan
« Reply #22 on: August 16, 2013, 12:29:41 am »
Anyone actually see/use the 139C yet?
« Reply #23 on: August 16, 2013, 12:39:42 am »
I held a sample in the Uni-T office before the release, but didn't have time to test it properly. It felt reasonably well made, but the low count (6000 max) put me off a bit.
Here is a picture of the meter I took at the time, while in China:
Offline Fsck
  • sleep deprived
« Reply #24 on: August 16, 2013, 12:55:41 am »
if you had one in your hand, should've distracted the workers and taken it apart.
"This is a one line proof...if we start sufficiently far to the left."
« Reply #25 on: August 16, 2013, 01:04:05 am »
I was more interested in their new oscilloscopes.
Offline Legit-Design
« Reply #26 on: September 09, 2013, 10:33:27 pm »
MCU inside my UNI-T UT139C, pic below. Found this picture on chinese site: http://translate.google.com/translate?hl=en&sl=zh-CN&tl=en&u=http%3A%2F%2Fzhidao.baidu.com%2Fquestion%2F563770993.html Mine had same MCU inside. At least is suspect it is mcu.
I can provide teardown photos if enough people are interested.
Yes, it has few movs and few ptc, 600V fuses. 10A fuse is physically smaller than "600mA" fuse, no room for bigger fuses and holders like UT61C/E series has.
NCV, non contact voltage is really sensitive, it has 4 ranges, one to four dashes and it beeps more with more dashes.
I just had excuse to take it apart, K-type temperature function was acting up. When it was in room temp it was 28 C when it should be 25 and when I heated it with my hand it went DOWN, I heated the tip with my lighter and temp went down to -200C. Now I took the batteries out and it's working normally again, room is 25 and hand is around 30, boiling water is around 98 to 99 C what is just tested, heat from lighter is really hot is just burned the heatshrink from k-type a bit. Earlier today I discovered if I short the temp input with a probe it showed me current room temp, but that wasn't the case. I put my meter in the freezer and it couldn't read the K-type properly anymore. It was around -20 below what it should be.
« Last Edit: September 09, 2013, 10:36:41 pm by Legit-Design »
Offline Lightages
  • Canadian po
« Reply #27 on: September 09, 2013, 10:38:21 pm »
I would like to see more images. :-+
« Reply #28 on: September 09, 2013, 11:27:49 pm »
http://imgur.com/a/984K7 Gallery with all the pictures.
Please excuse these amateurish shots, took these with my smartphone with flash on, most of them are in focus.
Backlight is quite weak compared to UNI-T UT-61D, but good enough to see in dark.
Meter feels rugged when handled, I wouldn't be afraid to drop it.
MOVs are http://www.thinking.com.tw/documents/en-TVR.pdf
TVR07681
« Last Edit: September 09, 2013, 11:29:34 pm by Legit-Design »
The following users thanked this post: Marco1971
Offline Monkeh
« Reply #29 on: September 09, 2013, 11:28:45 pm »
Well now, that looks a lot like a BS1362.
E: That's because it is, with a 600V/200A rating as well as 250V/10kA.
« Reply #30 on: September 09, 2013, 11:46:55 pm »
Oh and the most important things autoranging is slow, in resistance, like with UT-61D but Continuity beeper is super fast.
Binding posts are solid type and feel really good, much better than with my UT-61D/E. I have all three meters so I can do comparison.
Manual quotes screen updates 2-3 times per second, looks faster than UT-61D, but doesn't have that analog bar graph thing.
Max min includes Max-Min, so it shows difference.
EDIT: Few bits... that oscillator is soldered from its can to the board. Case is held by two self tappers, battery cover with the fuse inside is held by machine screw into metal insert.
More: microamps range resistance 101 ohms, milliamps 2,1 ohms, amps less than 0,10 ohms, amps range is really tricky to measure.  All measured with UT61E with probes relatived out.
 for UT61D those are microamps 50 ohms, milliamps ~0.8 ohms (I think dave also has covered ut61d in his 100$ MM shootout)
One more thing to point out, probes are super dull compared to normal uni-t 61d/e probes
Please check the gallery for more pictures: http://imgur.com/a/984K7/all
What else should I test with this meter? I don't have any accurate references, but I can do comparative measurements since I doubt all three of my Uni-t meter are out of cal.
« Last Edit: September 10, 2013, 02:11:01 am by Legit-Design »
Offline retiredcaps
« Reply #31 on: September 10, 2013, 05:29:45 am »
Does it overshoot?  That is, if you connect the UT139C to a DC or ATX power supply, does it show the correct DCV reading immediately?
For example, if the power supply is set to 12.0V DC and turned off and then on, does the multimeter show 18.1V (this is overshoot), then 12.3V, and then finally 12.0V?  Or does the UT139C show 12.0V right off the bat?
« Reply #32 on: September 10, 2013, 06:10:01 am »
Couldn't get any of my three meters (UT61E UT61D and UT139C) to overshoot with 12 volts.
However I could replicate https://youtu.be/3-_dUB8vy8U?t=25m27s Daves test from his shootout and get consistent overshoot with UT61D switching 3.3V rail. Sometimes 4.5V sometimes 4.7V, or even 5V, and I could get atleast 4.5V oveshoot consistently. UT136C didn't show any overshoot with this setup. Sometimes I could get UT61E to overshoot 18V or so, but that was more random than consistent. UT136C gets there more gradually it shows 2.3 to 2.9V for a split second before goes to 3.3V.
Offline lpc32
« Reply #33 on: January 13, 2014, 11:29:38 pm »
Any new info or opinions? I can't find a manual, nor any official info in the manufacturer site.
Offline lpc32
« Last Edit: January 15, 2014, 06:17:32 pm by lpc32 »
« Reply #35 on: January 20, 2014, 06:16:12 pm »
Frankie has these on his ebay store: http://www.ebay.com/itm/Uni-T-UT139C-True-RMS-Digital-Multimeter-Temperature-NCV-Backlight-/171213085325?pt=LH_DefaultDomain_0&hash=item27dd185a8d
For US $49.99 I recommend buying from him, fastest shipping on ebay I've seen (from Hong Kong).
Also a member on this forum https://www.eevblog.com/forum/profile/?u=26834. He can also source other things which are not listed on ebay.
And he ships fast, faster than any other ebay seller. He will remove those batteries from the package, but thats so that customs wont stop the parcel, I've had parcels sent back to seller because because some other parcel included batteries, so they stopped whole load of packages.
Some special prices for forum members:
https://www.eevblog.com/forum/buysellwanted/brand-new-uni-t-ut61e-for-sale/
Brand new Uni-T UT61E for sale
$55 (US customers) / $57 (non-US customers)
https://www.eevblog.com/forum/buysellwanted/fs-digitek-dt-4000zc-tekpower-tp4000zc-with-discount
Digitek DT-4000ZC / TekPower TP4000ZC with discount
It is listed at $36.99 (worldwide shipping included), but members can contact me here directly and get one for $35.
Offline retiredcaps
« Reply #36 on: January 24, 2014, 06:58:58 pm »
Video review and teardown by electronupdate, an eevblog member here, just posted Jan 24, 2014.
Franky gets a shoutout.
Offline electronupdate
« Reply #37 on: January 25, 2014, 02:27:15 am »
It's an interesting meter.  The calibration mostly appears to be set by inside a serial eeprom (no trim pots on the board).  Good for stability, not so good for service.  I could not find any details on the main controller IC.
The meter has 600V rated fuses which match the CAT rating which is also a step in the right direction (the previous ut61e I tore down used 250V BS1362 appliance fuses).
Another  item of note is that UNI-T needs a product manager.  Each meter they produce does not fit into a nice cadence of features.... one  always needs to make a decision on odd axis such as temp sensor versus resolution.
« Reply #38 on: January 25, 2014, 02:56:53 am »
Looks like they updated the board slightly, mine has silkscreen place for that bodged crystal. (
) That new board doesn't have that and SMD crystal is in place.
Offline lpc32
« Reply #39 on: January 26, 2014, 04:24:57 pm »
Thanks, electronupdate.
Re board changes, maybe there are different versions in different regions?
There are a few more details I wonder about, but I'll find out soon enough.
« Last Edit: January 26, 2014, 04:51:45 pm by lpc32 »
Offline lpc32
« Reply #40 on: March 12, 2014, 04:27:03 pm »
Some impressions:
Build quality feels decent.
The backlight turns off after a few seconds by itself. Quite annoying.
The probes' tips aren't sharp. Similar to a ballpoint pen.
Offline JonathanLee
« Reply #41 on: March 28, 2014, 04:52:26 am »
DTM0660L IS HYCON HY12P65 Digital Multi-function Meter (DMM) ICs
http://www.hycontek.com/e-page2-HY12P.html
Offline retiredcaps
« Reply #42 on: March 28, 2014, 07:02:11 am »
Thanks for sharing that information.  I would have never figured that out.
Offline awardcat
« Reply #43 on: July 19, 2014, 03:36:09 pm »
 :o but...this page says HY12P65 have 5000 counts , but ut139C have 6000 counts
update : in the datasheet is 6000 counts
Offline IGNT
« Reply #44 on: July 25, 2014, 04:44:41 am »
Woow that seems, good stuf ...  how can i buy it, in indonesia.  would you share me a presaller in indonesia who sale this good stuf...
regards
IGNITER
Note : Sorry About my English  language , because i javanese...  ;D
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #45 on: July 25, 2014, 05:15:09 am »
regards
IGNITER
Franky (iloveelectronics) on this forum sells this meter.
http://www.ebay.com/itm/171213085325
He ships pretty much worldwide from HK. You might be able to get it a tad cheaper via this forum as he doesn't have to pay ebay fees.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline IGNT
« Reply #46 on: August 08, 2014, 07:54:56 am »
thank's for nice reply, PedroDaGr8
, my apologize ,for late response.
Regardz
IGNITER
Offline boo9
« Reply #47 on: September 01, 2014, 01:24:09 pm »
Anybody has a link to a _searchable_ PDF for UT139C ?
Offline lpc32
« Reply #48 on: September 01, 2014, 05:15:21 pm »
Not searchable, but the PDF on UniT's site is better quality than the previously available one:
http://www.uni-trend.com.cn/uploads/soft/wanyongbiao/UT139A.UT139B.UT139C%20-Manual-en.pdf
Offline mariush
« Reply #49 on: September 02, 2014, 01:35:33 am »
Here, I OCR'ed it ... careful though, it's not proofread, no spell checking, just automated ocr .
Offline Ether
  • Country: my
« Reply #50 on: October 11, 2014, 06:08:21 am »
This meter looks pretty good. Just wondering, in comparison with the UT61E, does it outshine it in terms of usefulness? I understand that both have their pros and cons but does the resolution on the 61E outweigh the 139C's better input protection, NCV, backlight, auto power-off etc. ?
By the way, I'm asking because I'm looking to get another meter to complement my Fluke 73 III that has been really reliable but somewhat lacking in features so I appreciate any help.  :)
« Last Edit: October 11, 2014, 06:10:10 am by Ether »
Offline Creep
  • Country: lv
« Reply #51 on: October 11, 2014, 06:51:36 am »
Totally depends on what you want to use it for. If your thinking of probing mains a lot etc. then you probably want to go for the 139C. If your only working on the bench, then UT61E is your best bet I would say.
Offline Ether
  • Country: my
« Reply #52 on: October 11, 2014, 06:55:54 am »
Yeah, I think what you said made sense.
I think I'll probably get a UT61E for the bench and use my Fluke for any  high-voltage work.
After all, the 22000 count is really appealing to a guy with more than a few 6000 count meters.
« Reply #53 on: October 11, 2014, 07:10:04 am »
Don't rely on the last digit of the 61E.
The meter doesn't have an external voltage reference and in my experience drifts way too much for a 4 1/2 count meter.
Offline Ether
  • Country: my
« Reply #54 on: October 11, 2014, 07:24:34 am »
Then Wytnucls, in light of that, would you recommend the 139C over the 61E, seeing that the last digit is useless anyway?
« Reply #55 on: October 11, 2014, 07:37:40 am »
I guess so, as I would happily trade my 61E for a 139C. But compare features and get the one that fits your needs better.
« Reply #56 on: October 11, 2014, 03:10:49 pm »
I wrote elsewhere on the NCV function:
Having used UT139C I wouldn't put much if any value on having NCV, in my opinion it's way too sensitive for all kinds of fields. I actually went and got cheapest non contact volt meter pen from the store, it was 5€ and it can light led on which europlug hole is the live one. First pen I got didn't work a real piece of crap, even tried another battery, went to the store and got it exchanged and they even let me test the new was functional. Of course a meter is way too big to show anything with such accuracy, but UT139C picks up fields from all over the place. For example just measured full bars 80mm from my computer display that has ccfl backlight. If I bring my hand to closer to the meters sensor it will drop to 2 bars. A real non contact voltage pen doesn't react to display in any way. Also UT139C seems to pick up voltages from just simple metal surfaces around the room. UT139C thinks my headphone cable while only connected to computer has 4 bars worth of voltage, and I'm not even playing anything through the headphones can even disconnect and leave only the cable and it still thinks there is big voltages on the cable. Real cheapo voltage pen doesn't show anything for the headphone cable. Or maybe the unit I received is faulty and I opened mine and posted some pictures so it doesn't even have warranty anymore, or maybe it never had warranty since I bought it ebay china. I wouldn't advice anyone to trust their lives on UT139C NCV function, it's flaky and unreliable. If properly used a cheap non contact voltage pen might be something to rely on.
still just my opinion and experiences, your mileage may wary. the youtube review/teardown by a forum member only showed NCV when close to mains wire, and mine works just the same way with mains voltages, but it's the other things I'm worried about.
« Last Edit: October 11, 2014, 03:12:37 pm by Legit-Design »
Offline lpc32
« Reply #57 on: October 11, 2014, 03:33:07 pm »
...backlight...
The light turns off automatically after 15 seconds, and to turn it on you need to hold the button for 2 seconds, so I find it rather useless. Unless there's a hidden way to configure it to stay.
« Last Edit: October 11, 2014, 03:34:55 pm by lpc32 »
Offline Ether
  • Country: my
« Reply #58 on: October 12, 2014, 02:11:37 am »
I hope I'm not hijacking this thread by asking this, but does anybody reckon that the dt-2843r ot the dt-4000zc might be of better value in comparison to the 139C?
Offline n33d
« Reply #59 on: October 19, 2014, 05:01:23 am »
Hi All,
I am new to DMM stuff and UT139C is my first DMM. Just got it yesterday. :)
while playing with the meter, i've noticed that it behaved strangely when i test for resistance. i used my test lead and clamp them together, it showed 0.00 Ohm(expected 0.1 or 0.2ohm) but when i switched to continuity test, it showed 0.02. Test done on other wires and the pattern is consistent. Always +0.02 Ohm when switched to continuity
Is this "auto-zero" feature from uni-t??? :-//
« Reply #60 on: October 19, 2014, 05:35:27 am »
Resolution is 0.1 Ohm on the lowest 600.0 Ohm range with an accuracy of 1%+2, so assuming your test leads have a true resistance of 0.2 Ohm, any reading between 0.3 and -0.1 Ohm would be within specs.
« Last Edit: October 19, 2014, 06:02:01 am by Wytnucls »
Offline lpc32
« Reply #61 on: October 19, 2014, 04:55:58 pm »
I guess that depends on your requirements. Look for features you must have and see which meters match.
« Last Edit: October 19, 2014, 04:58:54 pm by lpc32 »
Offline Lightages
  • Canadian po
« Reply #62 on: October 19, 2014, 05:57:28 pm »
The main differences to consider IMHO:
DT2843R has True-RMS with DC, UT139C appears to be True-RMS AC only
DT2843R has a slow continuity test, UT139C is fast
DT2843R has limited input protection, UT139C has much better input protection
DT2843R does not have a non-contact voltage detector, UT139C has NCV
DT2843R has a better made temperature probe, UT139C is a simple welded bead end.
DT2843R 4000 count, UT139C 6000 count
DT4000ZC is close to the same as the DT2843R, but has PC connection and software.
Conclusion:
Need a safer meter, UT139C. Need fast continuity, UT139C or DT-4000ZC. Need NCV, UT139C.
Need True-RMS +DC, DT2843R.
Need PC logging, DT-4000ZC.
I would recommend the UT139C to most people from what I have seen. I have a DT2843R and it is a very good meter for the money too, but I think the UT139C edges it out for most uses.
Offline lpc32
« Reply #63 on: October 19, 2014, 10:02:24 pm »
Don't forget that value also includes price. :)
And there may be some differences in accuracy.
Offline jarvis
« Reply #64 on: October 20, 2014, 02:33:50 am »
Low AC bandwidth (1.5kHz) TRMS of UT139C seems not accurated for square wave or higher crest factor waveform even it is lower frequency.
« Reply #65 on: October 20, 2014, 03:44:31 am »
AC bandwidth is 1kHz. Crest factor up to 3.0 for low voltage signal which has to reach at least 5% of the range for accuracy.
That should cover square, triangle and half rectified sine waves.
« Last Edit: October 20, 2014, 03:48:22 am by Wytnucls »
Offline Ether
  • Country: my
« Reply #66 on: October 21, 2014, 11:04:18 am »
Thanks to everyone for the replies. I finally settled on a UT139C over the Digitek offerings after comparing the specs again. Personally, I think that the poor-quality temperature probe/thermocouple included can probably be replaced, albeit at an additional cost. The deal-breaker for me was the continuity. Slow continuity is a pain to work with and I would happily trade the True-RMS DC for fast continuity. The NCV and 6000 counts just sweetened the deal. I'll post my impressions after receiving it but from what it looks like, it looks pretty promising. By the way, anybody knows what the V.F.C means. I'm guessing variable frequency something, correct me if I'm wrong.
Offline HiTech
« Reply #67 on: October 21, 2014, 01:31:15 pm »
Don't worry about it .... after all, the old saying "you get what you pay for" is very often true. At the end of the day, it's still a $50 DMM from a company that probably trained field mice to assemble it to maintain a profit margin.
Offline lpc32
« Reply #68 on: October 21, 2014, 09:40:49 pm »
Another point: the UT139C's temperature resolution is only 1C.
VFC, the manual says, is for variable frequency voltage. Maybe someone else can shed more light.
Offline Lightages
  • Canadian po
« Reply #69 on: October 21, 2014, 09:44:18 pm »
The VFC function is supposedly a high roll off filter to reduce noise on the measurement from switched variable frequency motor drives.
« Reply #70 on: October 24, 2014, 11:27:26 am »
Also the temperature is all over the place when multimeter comes from the freezer, yes I tested mine, left it in the freezer and took it in the room temperature. It took a long time to warm up and start to show up reasonable temperatures. Maybe this is because there is no cold junction compensation? Or the temperature measurement is just crap. Might be a problem in some places where it is actually so cold it snows in the winter, and some people might want to use it to troubleshoot their car or something. But if used in normal room temperatures it might be of some use.
Having 2x AA batteries (UT139C) in a multimeter is a huge plus over single 9V battery (UT61E/D). Now that I've got to use mine and seems like the 9V batteries are flat way too soon. More time without battery warning icon means more measurements that are most likely accurate.
Offline Ether
  • Country: my
« Reply #71 on: November 03, 2014, 08:55:05 am »
I just received my UT139C. Haven't done any extensive testing yet but I must say, the construction quality is excellent. I especially liked the sturdy holster which would easily protect the meter from a fall off the bench. Backlight is acceptable as well and the selector wheel is nice to turn and relatively "clicky" but some might consider it too mushy. Included probes are acceptable but I recommend Fluke TL75 leads.  ;)
I tried to replicate Legit-Design's NCV problem. Unfortunately, I couldn't get it to go off at my earphones (plugged into a computer). However, I noticed that it works better with the holster off but I still wouldn't trust my life on this. Useful in a pinch but if you're doing high voltage work frequently,  invest in a proper voltage pen.  :o
The temperature probe is pretty cheap and only goes up to 230 celsius if I'm not wrong but this meter is only good for ballpark measurements due to its low resolution.
For a first impression, that's more all or less all the annoying flaws I spotted. Don't get me wrong though, this is an excellent meter for the price point and the features/cost ratio is superior to practically every other meter at this price point. Also, the input protection is properly designed with the standard MOVs and PTCs (600V) so this would be a better option for beginners as it is less likely to spontaneously combust if you screw up. Fuses are properly rated at 600V and are HRC fuses.
That's about it but I would be happy to try any other tests that others might suggest.  :)
Offline Monkeh
« Reply #72 on: November 03, 2014, 09:21:02 am »
If you'd trust your life to a voltstick, you're an idiot. They are for locating wires, not determining if they're dead or not.
Offline Ether
  • Country: my
« Reply #73 on: November 03, 2014, 09:46:06 am »
Perhaps I didn't phrase that correctly, but essentially, knowing where the wires are is pretty important if you don't intend to live a shorter than average life. Determining whether the wires are dead or not is a different matter so you do have a point there Monkeh.
Offline gigahertz
« Reply #74 on: November 03, 2014, 03:45:01 pm »
Gents,
On your web site is mentioned “Optional AC/DC 60A current clamps in different models to measure current up to 60A(1mv=1A)”;
Where can I found the current clamp? Has it a separate ordering code?
Regards!
Offline iloveelectronics
  • Country: hk
« Reply #75 on: November 03, 2014, 04:01:46 pm »
Gents,
Regards!
Uni-T actually don't have anything like that yet in their product line. You should be able to use any generic current clamps that work with multimeter though, such as this: http://www.amazon.com/Tecpel-CA-60-AC-Current-Clamp/dp/B002IRU3IM
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline SSchaffrath
« Reply #76 on: December 11, 2014, 01:08:57 pm »
Hi guys,
i blowed the small fuse up when i was testing it :D
Which replacement can i use, i cant find a 600ma 600v ceramic fuse...
Offline Lightages
  • Canadian po
« Reply #77 on: December 11, 2014, 10:16:47 pm »
I am beginning to think that Dave needs to enforce mandatory country settings in member's profiles. How many times do we need to ask people to tell us where they are so they can buy from the right place?
Franky has a 630mA 500V fuse but that does no meet the CAT rating. But I am sure if you ask Franky he can get the right fuse.
Offline SSchaffrath
« Reply #78 on: December 12, 2014, 04:24:09 am »
Im from Germany.
I tried it once to buy something from his ebay shop and it doesnt worked with German ebay.
  • Country: hk
« Reply #79 on: December 12, 2014, 04:50:51 am »
Im from Germany.
Is it still the case right now? As far as I know people from Germany should be able to see my store now http://stores.ebay.com/99centhobbies
I'm out of stock on the 630mA 500V fuses though. 600mA 600V is actually a tricky one to source...
Offline SSchaffrath
« Reply #80 on: December 12, 2014, 04:55:09 am »
Cool now i can see it :D
Last time i checked it, it was not possible.
Which alternatives do i can use for the UT139C ?
  • Country: hk
« Reply #81 on: December 12, 2014, 05:20:31 am »
I will try to source some 6x32mm 600mA 1000V fuse, which would be suitable for both the UT139C and Brymen BM257S that I sell. It will likely take some time though as these fuses are not common.
In the mean time I guess you can try to buy some 500mA 500V or above rated fuse, which should do the job just fine as long as you know the limitations.
Offline SSchaffrath
« Reply #82 on: December 12, 2014, 05:22:34 am »
Ok then i buy for the mean time your suggested ratings and when you sourced the suitable fuses for these meter then i buy some from you :)
Do i can use 6.3mmx32mm aswell?
  • Country: hk
« Reply #83 on: December 12, 2014, 05:26:42 am »
Yes, that should be fine. The sizes always vary slightly but the fuse holder should be able to accommodate them.
Offline Yago
« Reply #84 on: December 12, 2014, 11:56:24 am »
The 857S is out now 3Room.
They fixed the backlight (perhaps some other changes IDK)!
  • Country: hk
« Reply #85 on: December 12, 2014, 01:13:49 pm »
just curious @ franky, would you happen to have a ballpark price of brymen bm857a if you were to sell it?
I couldn't get good pricing on that model so I gave up a long time ago. The tme.eu pricing was (still is) incredibly low there's no way I would be able to compete.
Offline SSchaffrath
Offline lpc32
« Reply #87 on: December 12, 2014, 03:06:01 pm »
Aren't there more specific specs needed than just the current and voltage ratings?
SSchaffrath: Try ebay.com instead of ebay.de. Maybe not all international sellers are listed in the .de site.
« Last Edit: December 12, 2014, 03:09:54 pm by lpc32 »
Offline Lightages
  • Canadian po
« Reply #88 on: December 12, 2014, 05:56:35 pm »
If you look at the image of the fuses, you can see that they are also rated for breaking 10kA and have a UL symbol on them. Whether they actually are UL tested is another matter. The fact that they show a clean room and some kind of IC inspection or testing lab leads me to believe that they are not showing the actual environment they have for making fuses :bullshit:
Offline classical
« Reply #89 on: January 06, 2015, 07:51:03 am »
Could this be confirmed in the meantime? In the manual of the 139C I find all the three symbols listed (Table VIII "Knobs and Keys for Range selection").
« Reply #90 on: January 06, 2015, 09:08:19 am »
139C measures true RMS AC only. Bandwidth is narrow at 1kHz for voltage and current.
Offline classical
« Reply #91 on: January 06, 2015, 09:19:17 am »
Thanks for the reply.
Offline lpc32
« Reply #92 on: January 06, 2015, 03:59:57 pm »
Makes me wonder.  With a 1kHz bandwidth, what would you expect to see at 5/10/20kHz?
« Reply #93 on: January 06, 2015, 04:11:08 pm »
Something like this, but with the slope starting at 1kHz:
Offline lpc32
« Reply #94 on: January 06, 2015, 04:16:44 pm »
So as long as it's pure sine you can just compensate?
« Reply #95 on: January 06, 2015, 04:29:51 pm »
Probably not, as the curve could change shape with input voltage.
Offline lpc32
« Reply #96 on: January 06, 2015, 08:25:46 pm »
I see.
Offline andrija
« Reply #97 on: January 06, 2015, 09:17:59 pm »
These fuses go for 40-50 dollars EACH, as per Digikey. Even in 1000's quantities they cost $25. How can these $70 multimeters afford to have them (and you need TWO)?
Actually, it's just Digikey. Element 14 only charges around 8 dollars and a 5 pack on Ebay (in original packaging) is around 45 so it's not THAT bad. Not sure why Digikey charges so much, must be a pricing mistake.
« Last Edit: January 07, 2015, 12:50:23 am by andrija »
Offline eas
    • Tech Obsessed
« Reply #98 on: January 07, 2015, 04:41:56 am »
Has anyone explored the (unsoldered) header on the PCB (visible
VDD, WP, SLC, SDA, V1, and two labeled CAL?
« Last Edit: January 07, 2015, 04:55:56 am by eas »
Offline mmatic
« Reply #99 on: January 07, 2015, 06:06:56 pm »
Hey!
1.) Can anyone who owns this UT139C meter please measure burden voltage?
2.) What is measured accurancy at uA, mA, A range?
3.) Is contuinity test fast?
Best Regards Matic
Offline lpc32
« Reply #100 on: January 07, 2015, 06:49:18 pm »
1. Burden voltage: https://www.eevblog.com/forum/testgear/new-trms-uni-t-ut139c-dmm-is-available-now/msg289230/#msg289230
2. Accuracy beyond what's indicated in the manual?
3. Continuity is pretty fast.
Offline mmatic
« Reply #101 on: January 07, 2015, 07:05:54 pm »
Hi!
Do you maybe own ut139? Does this multimeter has better current accurancy that ut61e?
Best Regards Matic
Offline Lightages
  • Canadian po
« Reply #102 on: January 07, 2015, 10:08:38 pm »
I have had both and the UT61E  is rated more accurate of course but my UT139C is as accurate from my recollection.  It doesn't mean it will stay that way but it is as accurate as most people need.
Online ataradov
    • Personal site
« Reply #103 on: February 01, 2015, 03:00:30 am »
Does anyone know how the frequency measurement works? Is it only for AC voltage with positive and negative swings?
I'm trying to measure frequency on the MCU pin, which is 1 kHz, 0-3.3V, 50% duty cycle. And the meter shows 0.
At the same time if I touch any of the probes, I get 60 Hz (I'm in the US), so it can measure something.
Alex
Offline Lightages
  • Canadian po
« Reply #104 on: February 01, 2015, 04:55:29 am »
I can read 90mV P-P no problem at 1kHz on the Hz measurement selection on the dial. On the Hz subselection in ACmV I get a reading at around 50mV P-P.
Online ataradov
    • Personal site
« Reply #105 on: February 01, 2015, 05:17:11 am »
So it looks like it needs "hard 0v". With pullups on MCU pins, the logical "0" voltage is actually around 40 mV and this is not enough for frequency measurement.
I've put a battery between the ground lead and the circuit ground to offset the measured voltage and got proper frequency reading on the "Hz" setting. At the same time frequency measurement on AC voltage setting still shows 0.
Alex
Offline Lightages
  • Canadian po
« Reply #106 on: February 01, 2015, 05:57:21 am »
Sorry Alex, I didn't answer your question. I was busy doing something else and casually did a test that wasn't very helpful. I just did a test that was actually related to your question!
Yes, it seems that the frequency measurement needs a zero crossing. I was unable to read 0-3.3V with the meter. I was able to read the frequency by putting a 2uF cap in series with the probe. Try a cap of some value and I think you will get your measurement.
« Last Edit: February 01, 2015, 06:09:08 am by Lightages »
Online ataradov
    • Personal site
« Reply #107 on: February 01, 2015, 06:06:20 am »
Yes, using a capacitor is an option, but it becomes a hassle. I considered using a meter for quick frequency check to save time on powering up the scope. With the need to look for capacitor, it does not save much time.
Alex
Offline electr_peter
  • Country: lt
« Reply #108 on: February 05, 2015, 09:21:45 am »
From video reviews it seems that UT139C beeps whenever rotary dial is turned. Who thought it was a good idea? :palm: Is there a way to turn off this annoying beep?
Buttons also beep, right? Is there a way to turn off button beep?
HW mod would help (to disable beep by default) if only there is way to get info about selected continuity mode (to enable beep).
« Last Edit: February 05, 2015, 06:11:29 pm by electr_peter »
Online ataradov
    • Personal site
« Reply #109 on: February 05, 2015, 05:24:45 pm »
Yes, it does beep and it is indeed quite annoying. I have no Idea why manufacturers put all those blinky and beepy things all the time, it feels like they don't think their product is good enough without them.
I'd like too see a mod myself.
Alex
  • Country: lt
« Reply #110 on: February 05, 2015, 06:21:35 pm »
Why do designers think that beeping on any input/activity is a good idea? Do they want do drive us crazy? Turn on -> beep, rotate dial -> beep, press button -> beep, ... At least give an option to disable it.
I would force such designer to use computer keyboard and mouse where any button press leads to old style type writer loud key press sound. That will show them.
Does UT139C turn on/blink back-light on continuity as well as beep? If so, permanently disabling beep would do (almost) no harm for functionality. I have done so with some multimeters which have blink option.
Online ataradov
    • Personal site
« Reply #111 on: February 05, 2015, 06:25:41 pm »
It definitely does not turn on the back-light, I'm not sure what happens if the back-light is already on, I don't have the meter at hand, but I'm pretty sure it won't do anything special.
Alex
Offline Lightages
  • Canadian po
« Reply #112 on: February 05, 2015, 08:30:10 pm »
In the case of the back light indicating continuity, no. But if you want to mod the beeper then maybe connecting the back light to the beeper output in some way would be a good substitute. I think needing to look for the back light for continuity indications would be counterproductive.  though.
Offline Didix
« Reply #113 on: February 08, 2015, 08:39:57 am »
Gents,
Regards!
Why should I buy a separate $80 clamp when I can get complete clamp meter for $30?
http://www.amazon.com/dp/B005HOPRRK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1QZMU23HSUUOC&coliid=I3GLO3CT1DUA92
These words are not meant as a provocation!!
I really would like to know, why one should buy the UT139C plus the referenced clamp  instead of a UT61E plus the UT203?
-Didix
Fluke 76 | UT61E | UT139C | UT70A | UT50E | UT132A | UT33C | UT203 | UTG9002C
Offline Lightages
  • Canadian po
« Reply #114 on: February 08, 2015, 04:01:05 pm »
If you are going to be using a clamp meter it implies that you will be working on high energy circuits. The UT61E is not suited for high energy circuits at all. It does not have proper input protection. The UT139C has much better protection and appears to actually be built correctly for high energy circuits.
Until Uni-T brings out their current clamp for the meter, if they ever do, I would suggest getting a separate clamp meter. The UT211B is pretty good for the money but it is not known if it meets its CAT ratings neither. Good clamp meters tend to cost $200.
Offline omgfire
  • Country: ru
« Reply #115 on: February 08, 2015, 04:25:32 pm »
Can you explain 3x price difference between UT211B and UT210E?
  • Country: lt
« Reply #116 on: February 08, 2015, 04:27:44 pm »
It depends on what you do and what do you want to achieve. Do you need DMM only for electronics (low power stuff)? Then clamp is useless in any form. Do you need to measure high AC/DC currents? Then you need a clamp.
Clamp with built-in DMM or DMM plus separate clamp adapter - again, it depends. Clamp with built-in DMM has an inconvenient form factor (too massive, too long, too narrow, no stand), but is only one piece instrument.
Price and characteristics wise you have to choose yourself - all depends on requirements.
Offline edavid
« Reply #117 on: February 08, 2015, 04:29:31 pm »
Why do you say that?  I only use mine on household circuits.
Offline Didix
« Reply #118 on: February 15, 2015, 07:04:45 am »
Now I got a UT39C, too.
I thought, the NCV could extend the features of my DMM collection.
However, the reach of the NCV is very moderate. The line needs to be closer than a half inch.
I was not able to detect any line inside my walls (230V).
Somehow disappointing experience ... :-\
-Didix
Online ataradov
    • Personal site
« Reply #119 on: February 15, 2015, 07:12:03 am »
I think its primary function is to find out if those uninsulated wires sticking out of the wall will kill you if you want to do something with them, and not finding wires behind the wall.
Alex
« Reply #120 on: February 15, 2015, 07:22:48 am »
Best use of a NCV test is to see if a cable is broken internally, and near which end the break is. You have to be right next to the cable and run down the length, and then it works well.
To detect cabling in walls you are much better off using a stud finder that has a cable detector built in as well, it is a more specialised part more appropriate for this use. I have one, even though most walls here in SA are brick, it does work to tell where the buried conduits are before drilling into a wall to avoid a very nasty surprise.
Offline Didix
« Reply #121 on: February 15, 2015, 07:52:10 am »
Ok, good points!
-Didix
Offline Maxlor
« Reply #122 on: February 15, 2015, 12:13:59 pm »
The UT211B is TrueRMs, the UT210E isn't. The UT211B also has a 600mA AC (but not DC) range, which might make it useful as a leakage tester.
From my point of view, as a hobbyist mainly playing with low power DC circuits, the UT210E is far better value for money.
Offline Lightages
  • Canadian po
« Reply #123 on: February 15, 2015, 03:09:09 pm »
Actually household circuits, if you are referring to house wiring, are considered high energy. If I remember correctly, the distribution panel and any circuits within 10 meters of the panel.
Offline Lightages
  • Canadian po
« Reply #124 on: February 15, 2015, 03:13:06 pm »
The UT210E is TRMS. The main differences I see are the current ranges, and the UT210E is 2000 count and the UT211B is 6000 count with slightly better accuracy specifications.
Offline edavid
« Reply #125 on: February 15, 2015, 08:06:48 pm »
Do you have a citation for that?  I don't think it's true here in the US.
Offline naughtilus
  • Country: mk
  • If it ain't broke, fix it anyway.
« Reply #126 on: February 28, 2015, 07:58:14 pm »
For the Uni-T UT139C we need the SIBA 7012540.0.630 (page 620), which is 700VAC, 630mA, 50kA, ceramic w/filler and 6.3mm x 32mm.
Found these sources doing a google search: DIYtrade.com and 11467.com (no affiliation). Indicatively prices are under $8 for 100 unit lot on these, which is not bad for a difficult to find fuse I reckon. Any group buys organized before on this forum or maybe Franky is interested offering this type of fuse for his ebay store (where I got my 139C originally)? Franky, do you do pre-orders where we give you money and when there is at least 100 of us you buy a lot and send us the fuses? Small amount per person at stake and we are all bound eventually to blow the voltage fuse considering this is somewhat of an electricians DMM, not for bench work really. I bought it to poke the mains at home.
Thoughts?
« Last Edit: February 28, 2015, 08:07:22 pm by naughtilus »
...or is it?
Offline Lightages
  • Canadian po
« Reply #127 on: February 28, 2015, 08:16:36 pm »
Actually, a US company says so! The most concise explanation comes from Fluke. It isn't a very rigorous explanation but it does confirm my assertion.
http://www.fluke.com/fluke/m2en/training/safety/
Look for ABCs of multimeter safety.
This is why I almost always suggest a properly rated meter for even casual bench users. The temptation to use it on home wiring is too much.
Offline edavid
« Reply #128 on: February 28, 2015, 08:46:39 pm »
That document does not define "high energy".
Anyway, it says that CAT III is three-phase distribution, so doesn't that mean that single-phase house wiring would be CAT II?
Offline naughtilus
  • Country: mk
« Reply #129 on: February 28, 2015, 09:14:56 pm »
I have three-phase outlets (400V) in my house. Those would be CAT III most likely.
...or is it?
Offline Lightages
  • Canadian po
« Reply #130 on: February 28, 2015, 09:37:29 pm »
Do I need to read everything and repeat for everyone?  :-//
''Within a category, a higher working voltage”
(steadystate voltage) is associated with a
higher transient, as would be expected. For
example, a CAT III 600 V meter is tested
with 6000 V transients while a CAT III 1000 V
meter is tested with 8000 V transients."
"CAT III Three-phase distribution, including • Equipment in fixed installations, such as switchgear and polyphase motors.
single-phase commercial lighting • Bus and feeder in industrial plants.
• Feeders and short branch circuits, distribution panel devices.
• Lighting systems in larger buildings.
• Appliance outlets with short connections to service entrance."
Offline naughtilus
  • Country: mk
« Reply #131 on: February 28, 2015, 09:45:04 pm »
Transients... pffft. Just roll the dice man!  O0
...or is it?
« Reply #132 on: February 28, 2015, 10:26:56 pm »
A three-phase outlet is considered CAT III, as is a single-phase outlet within 10 meters of the distribution panel.
Offline Lightages
  • Canadian po
« Reply #133 on: February 28, 2015, 11:26:31 pm »
Obviously "High Energy" is a relative term. I think that anyone with experience with electricity would agree that Class III would be classed as "High Energy". This, especially, when compared to bench electronics energy levels.
Offline naughtilus
  • Country: mk
« Reply #134 on: February 28, 2015, 11:36:20 pm »
Basically everything in my house is CAT III since everything is within 10m radius from the distribution boards.
The Uni-T UT139C + Fluke TL71 leads seems good enough for measuring single phase <240Vac at home and <24Vdc/1A for hobby projects. Not sure if I wanna poke in the 3-phase outlet though... I'd call it CAT II and CAT III-ish.
« Last Edit: February 28, 2015, 11:42:30 pm by naughtilus »
...or is it?
Offline Lightages
  • Canadian po
« Reply #135 on: February 28, 2015, 11:42:43 pm »
Yes! You understand now. I am glad someone will know their risks and won't be blindly poking probes where they could be a hazard. Now you know the risks and can asses them to your liking instead of just thinking you are safe.
Offline naughtilus
  • Country: mk
« Reply #136 on: March 01, 2015, 12:33:20 am »
Also it seems leaving the protective caps on the leads increases their CAT rating. This is most likely because by reducing the exposed metal tips area, chances of arc flash occurring during a large transient when you pull out the tips are greatly reduced. HV cutouts between the inputs and fuses also seems to help prevent this. Plasma ball in your face can't be fun.
That Fluke ABC pdf is a fun read. Thanks for sharing LA.
« Last Edit: March 01, 2015, 12:40:11 am by naughtilus »
...or is it?
« Reply #137 on: March 01, 2015, 01:29:19 am »
For three-phase outlets in Europe, the voltage to consider for IEC CAT III environment is between neutral and any phase (230V 50Hz), not the voltage between two phases (400V 50Hz).
There is a big jump in transient energy test between CAT II and CAT III/CAT IV, as the voltage source impedance is reduced from 12 Ohms to 2 Ohms.
If the UT139C lives up to its CAT rating, it's all good up to 600V in a CAT III environment. Of course, without independent testing, that CAT rating is not to be trusted.
« Last Edit: March 01, 2015, 02:23:42 am by Wytnucls »
Offline naughtilus
  • Country: mk
« Reply #138 on: March 01, 2015, 01:37:21 am »
For three-phase outlets, the voltage to consider for IEC CAT III environment is between neutral and any phase (230V 50Hz), not the voltage between two phases (400V 50Hz).
So 400V between phases for a domestic plug within 10m distance of the dist. board is what category?
BTW. How's for safety? Or   :wtf: The future Photonicinduction?
« Last Edit: March 01, 2015, 01:41:26 am by naughtilus »
...or is it?
« Reply #139 on: March 01, 2015, 01:51:35 am »
Three phase outlet, regardless of distance is CAT III, requiring a meter rated CAT III 600V minimum, being lowest voltage for CAT III.
« Last Edit: March 01, 2015, 01:53:57 am by Wytnucls »
Offline naughtilus
  • Country: mk
« Reply #140 on: March 01, 2015, 02:17:31 am »
Thanks.   :)
...or is it?
Offline mos6502
  • Country: aq
« Reply #141 on: September 11, 2015, 11:38:43 pm »
Looks like the boards went through a few revisions. I've attached pics of the PCB of the meter I got some three weeks ago. The first in this thread was marked 190612-1, mine is 190612-4, so presumably it's the fourth revision. As you can see, they added another MOV. The board also looks better made than the the old one, all the components are straight and the soldering looks excellent.
for(;;);
Offline mematyi
  • Country: hu
« Reply #142 on: October 03, 2015, 02:30:46 pm »
Hello there!
I just got this meter, and well it is quite good for the price. Mine is also the 4.th revision.
I wonder if anyone read the chip's datasheet? It says that there are serial output.
There are also connections on the PCB for communicating(sda,scl) and for calibration  :-//
Apparently the "cal" traces do not lead to the mcu, but the RMS chip if i am correct
Offline Ichabod
« Reply #143 on: December 24, 2015, 12:20:45 pm »
But i ask me where UNI-T takes the other 1000 Counts   :box:  - on HYCON stands 5000 only!
Offline Electro Fan
« Reply #144 on: December 24, 2015, 07:54:09 pm »
On a related question, why wouldn't the manufacturer read the half a zillion posts about the UT61E and their other models and either modify or add one or a few models that better address the user feedback?
Seems like they have the ability to make many different models - why not put the most popularly requested features into one or two really, really well-received combinations?
No doubt, the UT61E has done pretty well - but it could be even more successful.
As it is you can choose model A with this and this but not that and that, or you can get model B with that and that but not this and this.  I could understand it if they only made one or two models but when they have a bunch of models why not add a backlight here and a whatever there?
The manufacturer would probably say "we've studied the market and segmented the market by user types and use-cases and we've determined that the profile of a person who buys a UT61E is someone who has $45 not $48 and they don't value having a backlight".  On the other hand, we have found the profile of a UTXYZ customer and they have even less money but they like to see their digits in the dark."
The answer is that in most companies the Marketing department that does "outbound" marketing communications rather than the "inbound" determination of market requirements and opportunities.  Meanwhile Engineering is generally too busy and often doesn't have the skill set, experience, budget, or charter (at least one of the above is missing) to sort through the signals and noise in the market, and the Sales people get listened to even less than the customers.  As a result you get a hodgepodge of "almost" products in a product family all scattered around the targets rather than hitting any of the targets squarely.  Of course since the targets change over time (due to changes in technology and competition as well as use cases) it's an evolutionary process but the low hanging fruit is to thoughtfully incorporate user feedback regarding current products.  It sure does seem like the DMM market could benefit from better product planning rationalization.
Having said all that, it's probably easier to be a critical customer than a successful product marketing manager. :box: :)
« Last Edit: December 24, 2015, 08:02:32 pm by Electro Fan »
Offline Lightages
  • Canadian po
« Reply #145 on: December 24, 2015, 08:44:52 pm »
I have come to the conclusion that multimeter manufacturers really don't spend much time worrying about customer feedback. They seem to design in the dark and think they are designing to lead the consumer. The exception seems to be Uni-T. They seems to just make a whole pile of different models with as many variations as possible and hope tat something sells. If they were actually trying design for what people want, then they could cut down their range of models to 1/10 of what they have now.
Offline adrianf88
« Reply #146 on: January 24, 2016, 07:36:10 pm »
Hey there everyone, a few months ago i was looking at the 139c as my next buy but i just couldn't source it locally. I know Franky is an ebay seller that everyone recommends around here, and i was going to buy it from him. But after i bought several items from ebay and recieved them all banged up by the local mail and customs office and by no fault of the seller i decided to wait for it to be available locally
A few days ago i finally found it in a store in my city and next thing tomorrow after i leave work i plan on buying it.
But seeing that its price is a 1/5 of my monthly salary i do feel like i should bury my impulses and think about it for a minute or two.
My questions are:
How reliable is it for bench operation only?
How much drift should i expect after 1 year? What about 5?
Can i calibrate it once it drifts?
When something eventually goes poof! and releases the magic ghost, how likely am i to find the necessary parts and documentation for the repair?
Thank you all for your time in advance!
« Last Edit: January 24, 2016, 07:37:43 pm by adrianf88 »
Offline joeqsmith
« Reply #147 on: January 24, 2016, 08:15:53 pm »
Difficult to know what you do on your bench.
Good question.  The two I have purchased only lasted a few hours after removing them from the box.   >:D
I assume you mean align it and I would doubt it.
These meters are what I would consider disposable.  The two I damaged took out the control IC and I was unable to do anything with them.   Some of the meters I have tested had enough protection to at least save the main controller.   These I have been able to repair.
The PCB shown appears to be the same as what I had ran.  Notice the two unpopulated clamps.   I do wonder if the controller IC would have survived if these were populated but those four diodes cost money!
Offline adrianf88
« Reply #148 on: January 24, 2016, 08:26:06 pm »
What i do on the bench is mainly hobby type stuff, amps, led's, repair broken stuff around the house (monitors, tv, etc) stuff like that.
What did you do to them that they only lasted 2 hours?
I know the term calibrate, i have 0 ideea what you mean by align.
Well, do you have any ideea what diodes were supposed to go there? If so, we can add them on our own. :D
Offline joeqsmith
« Reply #149 on: January 24, 2016, 08:47:21 pm »
If you are playing with line voltage stuff and you have some sort of clamp and breaker, the meter itself should be alright if you know what your doing.
The two I had were purchased for the purpose of attempting to see how robust they were.   They were both tested to failure and were not repairable.
In my own neck of the woods, Calibration is going to be verifying that the equipment is within the manufactures tolerances using some traceable means.    If the equipment is out of calibration, we would have it Aligned to bring it back into tolerance.
I would guess they would have used the same parts that were used for the other clamp but I would NOT recommend that ANYONE would EVER attempt to make ANY changes to a meter they plan to use for ANY high energy work!!!
Offline adrianf88
« Reply #150 on: January 24, 2016, 09:36:47 pm »
Yeap... I would most definitely do some mains stuff... Testing live wires mostly... But not just sticking the probes in the outlet for the kicks  :-DD  Hence the need for NCV but anything more than that, i don't think so.
But still some questions remain...
Offline adrianf88
« Reply #151 on: January 25, 2016, 05:53:14 pm »
Guess what... I bit the bullet and i bought it... I'm the proud owner of a brand spanking new Uni-T UT139C and i love it. I'll just have to see if it was worth the money in the long run...
Offline john_p_wi
« Reply #152 on: January 25, 2016, 06:27:23 pm »
Adrian, I'm sure it will be fine as long as you don't do something stupid with it.
I bought one from Franky over the Holidays and it seems to be a great little meter for general bench use.  So far I have only used it in concert with other meters in the development of a low voltage tube filament soft start supply with LED go - no go indication.  The only complaints that I have so far are 1) It shuts itself off too quickly and 2) the resistance reading update time is slooow.  That is OK, I'll just use one of my Flukes for resistance measurements.
Actually, I'll probably order another with a set of mini clips - it is just too handy for general bench use.
Offline Simon1983
« Reply #153 on: February 15, 2016, 10:29:08 pm »
I also got an 139C some month ago. I already had an Ut81B (the scopemeter) ansd it worked well, but was replaced with a Rigol DS1054z. The 81B is still in use for work at cars, where a scopemeter is handy. On the bench I only use it because it runs from mains over the power plug.
But I really love the UT139C. Is has fast display update speed, good continuity tester, ans its the first UNI-T I own thas really has input protection and big fuses. The only small drawback (as already mentioned) is the auto-off feature. Yes, and if you would want to calibrate it and adjust it to your reference, you can't: No pots in there, just an eeprom which (possibly) stores the calibration data. The UT81B has pots and I trimmed them to match the UT139C so I would have matching meters (good when using both meters in one circuit).
Greetings from Germany
Offline mos6502
  • Country: aq
« Reply #154 on: February 16, 2016, 04:42:38 am »
You can disable the auto-off feature. Hold select while turning the meter on.
for(;;);
Offline Martini
« Reply #155 on: March 26, 2016, 03:13:33 pm »
Hey!
I'm probably going to pull the trigger on a UT139C in the coming days. I found it listed at 33 € shipped and that seems very reasonnable compared to a Vichy VC99.
I don't think I'll miss the bargraph. One thing I'll miss, though, is the carrying pouch. Any advice on where to find one? Or keywords for the eBay/aliexpress search?
  • Country: hk
« Reply #156 on: March 26, 2016, 03:49:22 pm »
Hey!
I sell one in my eBay store which fits the UT139C rather well: http://www.ebay.com/itm/Double-Layer-Zipper-Carrying-Case-Bag-for-Multimeters-Fits-UT61E-Fluke-87V-/171047385726
Offline freebil
  • Country: gr
« Reply #157 on: May 13, 2016, 02:39:47 pm »
  Hello. I would like to buy the ut-139 but I saw that it can measure frequency up to 10Mhz. The ut-61e can measure up to 220Mhz I think. The difference is big but maybe I will go with ut-139c because of the protection and its nvc.
  As I read here its board has different versions and the last version is the fourth. Are there any differences between the versions? May I assume that the last version is better? Thanks
Hello there!
I think this link is useful:
http://www.kerrywong.com/2016/03/19/hacking-dtm0660l-based-multimeters/
« Last Edit: May 13, 2016, 09:27:06 pm by freebil »
Offline Tainer
« Reply #158 on: May 14, 2016, 02:51:16 pm »
I can't tell you about different versions, but if you're planning to buy this meter then keep in mind that frequency measurement will only work if the signal has no DC offset. For instance, you won't be able to measure a 0-3.3V PWM from microcontroller and so on. You'll have to AC-couple the signal with an external capacitor.
Offline freebil
  • Country: gr
« Reply #159 on: May 14, 2016, 04:02:21 pm »
Thanks for the answer. Can ut61e measure it if it has DC offset?
Offline Tainer
« Reply #160 on: May 14, 2016, 05:12:45 pm »
I don't have a 61E, but user manual says "Input amplitude: (DC electric level is zero)", so I presume the answer is no.
Offline freebil
  • Country: gr
« Reply #161 on: May 16, 2016, 01:45:30 pm »
Ok! I pulled the trigger and I ordered one! Are there any alligator clips that can be used with the probes? Maybe these? Thanks.
« Last Edit: May 16, 2016, 03:55:01 pm by freebil »
Offline pmason
« Reply #162 on: July 03, 2016, 03:21:32 pm »
I just received mine from China yesterday. I don't know of any alligator clips that are going to work with the probes.  Just buy a set of alligator test leads.
The UT139c feels very good in the hands, and I really like the ability to snap the probes into the back of the case.   :phew:  The probes are not sharp though.
Offline hugatry
« Reply #163 on: July 03, 2016, 03:44:47 pm »
Those need leads that have 4mm banana plugs on both ends. I haven't tested, but these should work with the probes that came with the meter.
Offline freebil
  • Country: gr
Re: New TRMS Uni-T UT139C DMM is available now
« Reply #164 on: July 05, 2016, 09:49:09 am »
Anyone with 5th revision of the board? Or the last revision is 4?
Offline electrifying
  • Country: no
« Reply #165 on: July 28, 2016, 10:28:07 am »
What about the current clamp? Does anyone of you have a current clamp for this meter? And if so, where did you buy it? I have been looking around ebay now but the current clamps I can find cost more than the multimeter itself and mostly have a BNC connector. Am I just using the wrong search phrase? The link to a clamp on Amazon from earlier in this thread sais "currently not available". What's the purpose of the clamp connection if it's cheaper to just buy a complete clamp meter instead of an external clamp for the multimeter?
Offline crazyguy
« Reply #166 on: July 28, 2016, 02:19:11 pm »
MS3302 Digital AC Clamp Meter
http://www.p-mastech.com/product/detail/392
  • Country: no
« Reply #167 on: July 29, 2016, 08:13:26 am »
That one would probably work, but only for AC by the looks of it. I would like to have a clamp that can also measure DC. I think it must have hall-effect sensors to measure DC. Strange that UNI-T does'nt offer any clamp at all when they advertise that the meter can be used with a "optional current clamp". I bought the meter thinking that I would just buy a clamp for it as soon as I need one... Maybe they are afraid that offering a reasonable current clamp for the UT139C could ruin the sale of their clamp meters...?
Offline classical
« Reply #168 on: July 29, 2016, 09:39:13 am »
Sensitive DC clampmeters are not cheap and have to be "calibrated" directly before andin the place of the measrement to compensate the magnetic field of the earth.
Some years ago a bougt a CA 60 from German ELV.de for about 70 EUR. It is "just" a converter i-> u with 1 mV/10 mA: up to 2 A or 1 mV/100 mA for i> 2 A. You need an additional Multimeter or a scope.
If you need 10 times higher resolution next would be Chauvin Arnoux E3N or K1 about 400 to 500 EUR.
Offline freebil
  • Country: gr
« Reply #169 on: August 23, 2016, 08:29:41 pm »
Hello. The 2 fuses are blown now. Where I can find cheap alternatives? I see that the one is 6X32mm(600V, 600mA) and the other 6x25mm(600V, 10A). I found some 250V and maybe I will go with them. The glass fuses are far inferior to ceramic?
Offline cpalha
  • Country: pt
« Reply #170 on: December 14, 2016, 09:35:14 pm »
Hi friends
Recently I buy one UT139c from ebay.
But has a problem with temperature measurement, when I compare teperature measuremente, the UT139c, gives less 8ºc from reality.
I check with other k thermocouple, but the difference are the same, and there is no polarity change.
What I can do with this problem? The guy from ebay sais that can refund, but it is only the temperature.
Any ideas to resolve this problem? This ut139c has some temperature sensor inside that can be damaged?
I would prefer try to resolve the problem or change for a newone, but from ebay seems the only solution will be the refund, and this way is no fair to the seller.
Best regards
cp
Offline Macbeth
« Reply #171 on: December 14, 2016, 09:43:45 pm »
Hi friends
Best regards
cp
There is likely a trimmer inside to calibrate the temp. In fact I've found many DMM's with 2 trimmers, 1 for each scale C or F, which is absurd. (Oh are you sure you are reading the correct units C or F?)
If all the other functions on the meter appear in good calibration then a twiddle of one of these trimmers while your K probe is in the vicinity of a known good thermometer is probably all you need to fix it.
eta: Measuring temps using thermocouples requires a cold junction compensation. In a lot of hand helds this will just be hard-coded to a typical 25 celcius lab temp. If your environment is hotter or colder than this then that is why you have a problem.
« Last Edit: December 14, 2016, 09:50:19 pm by Macbeth »
Offline cpalha
  • Country: pt
« Reply #172 on: December 15, 2016, 09:05:29 am »
Hi Macbeth
Thanks for the answear.
I compared the measure in degrees celcius with a good thermometer from my lab.
In page (6) of this thread we can see the pcb board inside the ut139c and i dont see the trimmers, but i will open it.
best regards
cpalha
« Last Edit: December 15, 2016, 09:10:09 am by cpalha »
Offline Kbird
Re: Uni-T UT139C DMM
« Reply #173 on: January 24, 2017, 12:01:17 am »
Hi , new Member here but I have been reading the Forums for a while and Ordered a Uni-T 61E, for playing around with small projects at home and measure the odd line voltage thing at work, but at least to me it was doing strange things like when auto ranging while measuring AC voltage of an outlet and getting stuck in Manual mode, so I returned it and replaced it with the UT-139C having read about it here too and knowing it was safer for AC measurements anyway since it has 600v Fuses not 250v  like the UT-61E . However I am sure the 61E was able to do the Red LED test as can my Old POS DMM I have had for 15-20yrs, but my new 139C doesn't seem to be able too ...or I am doing something wrong ?
Is there a good Tutorial on Testing a DMM , incase this one needs to go back too while it can, it seems okay autoranging on AC unlike the 61E ...thanks.
Also I always seem to have an issue measuring AC at an Outlet easily , so my thought was to splice a polarised Lamp cord ( so you can't get it wrong) into a set of cheap DMM leads I still have hanging around in the Shop , and use that instead of the probes?.
Thanks for your help/comments
KB
Uni-T UT-139C
Uni-T UT-210E                  Electronics Noob....
MC-52-0055-6
Offline totalnoob
« Reply #174 on: January 24, 2017, 01:25:26 pm »
Not really a tutorial, but if you go to Youtube and look for, I believe its, MLorton he tested a boat load of meters a few years ago and he uses a multimeter test board that he purchased online and goes through each test in those reviews.  I believe in one of his videos, or in the comments he tells you where he purchased it from.  It contains known values for the various functions that you can test your multimeter against.  Without something like that, you are really just guessing as to whether your meter has a problem or not, although you can probably get close enough if you have multiple multimeters that give approximately the same reading.
Offline Kbird
« Reply #175 on: January 24, 2017, 09:22:04 pm »
Thanks Total Noob , I do know MJLorton's Website , so I will have a look there for sure , it is possible there are just functions etc of this meter my old POS DMM doesn't have and I am doing something wrong , it's why I upgraded , it doesn't even have a continuity setting (or buzzer) and I wanted to play around with Arduino etc as well as Household Repairs etc.
https://www.youtube.com/user/mjlorton
Uni-T UT-139C
MC-52-0055-6
Offline Shadowjump
  • Country: gr
« Reply #176 on: February 09, 2017, 07:47:57 pm »
I just got it today. Is there any way to keep the backlight on? It turns off so fast that there is no point in turning it on.
Offline Kbird
« Reply #177 on: February 09, 2017, 08:56:28 pm »
I just got one too and think 15 secs is too short as well, but the only fix for it is if you are willing to hack the Firmware on the DMM Chip , it has been done by many, more savvy than me though :)  see Kerry Wong's Page about it here..... you don't need to do the whole hack just for the backlight ie adding the IR receiver/sender etc you just need to change the hex file correct and upload it to the chip. you can apparently make it a 8000 or 9000 count meter too.
The audible chirp when using the dial can't be fixed ( needed for continuity buzzer too) but it doesn't bother me like some, I did see a post saying to add some hot glue to the sensor/speaker to lower the volume works though.
KB
« Last Edit: February 09, 2017, 10:03:29 pm by Kbird »
Uni-T UT-139C
MC-52-0055-6
Offline Martini
« Reply #178 on: June 21, 2017, 01:52:44 am »
Great!
Sad.
Offline Kbird
« Reply #179 on: July 14, 2017, 04:39:11 pm »
Great!
Sad.
I did end up modding my 139C , with the Help of FrozenFrog over on this thread....
https://www.eevblog.com/forum/testgear/uni-t-ut139c-lcd-biasing-(schematics-avail)/msg1165035/#msg1165035
KB
Uni-T UT-139C
MC-52-0055-6
Offline darmach
« Reply #180 on: July 16, 2017, 03:10:07 pm »
Guys, I'm looking for a new mmeter - this or Uni-t UT61D? Why?
Im interested in precision, reliability and speed .)
I can also buy an used Metex M-3850D similar price, maybe that?
Offline Kbird
« Reply #181 on: July 16, 2017, 04:58:45 pm »
I am no expert on MMeters ( or electronics)  but I returned my 61E ( getting stuck in autorange it seemed) and got the 139C ( safer for mains voltage which I wanted) and am happy with it so far, and recently picked up the UT-210E mini Clamp meter to complement it too. And I have now hacked both based on posts here (and elsewhere) to add/change a few features.
more info on that here https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/
and
https://www.eevblog.com/forum/testgear/uni-t-ut139c-lcd-biasing-(schematics-avail)/new/?topicseen#new
Uni-T UT-139C
MC-52-0055-6
Offline darmach
« Reply #182 on: July 16, 2017, 06:49:15 pm »
and
And how do you felt the quality, and working with them? Which one seem to be faster, more convenient?
Offline Kbird
« Reply #183 on: July 16, 2017, 08:56:44 pm »
and
I did not have the 61E long but they seem about the same from what I remember , I am happy with the 139C , i have used it alot on the Bench , modifying so old Gameport Joysticks and throttles to USB and messing with Arduino etc and also at Work to check Voltages and Temperature to which was handy.
the 210E wouldn't be a good Bench MMeter, but is handy if you work on Vehicles etc too or want to check Appliances etc with the Clamp .
I don't know the Metex at all , perhaps some-else will post about that, perhaps it's a good buy ? though if you need Data logging it and the 61E are the only two to do it. there is an old post on that meter from 2013 I just found here :
https://www.eevblog.com/forum/testgear/metex-m-3850-dmm-good/
If you want a cheaper meter ($20-25) to play with or as a backup to your main MMeter , there is alot of talk about the AN8008 in this thread :
https://www.eevblog.com/forum/testgear/an8008-us-$19-10000count-1uv-0-01ua-0-01ohm-resolution-meter/
« Last Edit: July 16, 2017, 08:59:11 pm by Kbird »
Uni-T UT-139C
MC-52-0055-6
Offline MosherIV
« Reply #184 on: July 16, 2017, 11:33:25 pm »
Go with the UT139 for your new meter.
If you truely are after precision, you should be looking much more up market - 4 digit meters and above. Now you are into bench meter territory, which generally are not as reobust as the hand helds.
Also, precision and speed do not generally go together. You either want precisionand accuracy and are prepared to wait for the measurement (though now a days they take 10+ measurements a second) or you want speed and sacrifice precision/accuracy.
Offline darmach
« Reply #185 on: July 17, 2017, 05:06:16 am »
Ah, that's a very good advice. Most likely I wanted a holy grail then! .) Thank you!
Offline darmach
« Reply #186 on: July 20, 2017, 06:24:52 am »
Oh and the most important things autoranging is slow, in resistance, like with UT-61D but Continuity beeper is super fast.
Binding posts are solid type and feel really good, much better than with my UT-61D/E. I have all three meters so I can do comparison.
Manual quotes screen updates 2-3 times per second, looks faster than UT-61D, but doesn't have that analog bar graph thing.
Max min includes Max-Min, so it shows difference.
EDIT: Few bits... that oscillator is soldered from its can to the board. Case is held by two self tappers, battery cover with the fuse inside is held by machine screw into metal insert.
More: microamps range resistance 101 ohms, milliamps 2,1 ohms, amps less than 0,10 ohms, amps range is really tricky to measure.  All measured with UT61E with probes relatived out.
 for UT61D those are microamps 50 ohms, milliamps ~0.8 ohms (I think dave also has covered ut61d in his 100$ MM shootout)
One more thing to point out, probes are super dull compared to normal uni-t 61d/e probes
Please check the gallery for more pictures: http://imgur.com/a/984K7/all
What else should I test with this meter? I don't have any accurate references, but I can do comparative measurements since I doubt all three of my Uni-t meter are out of cal.
Hi, you wrote that you have both ut139c and ut61E. Can you compare autoranging speed between them? Measurement speed? I'm torn between these two.
Offline hans_ober
  • Country: in
« Reply #187 on: July 29, 2017, 05:12:45 pm »
Was considering purchasing this meter based on all the reviews I've read. I'm an EE student, and will use it for hobbyist electronics work, plus electrical work around the house (and fixing electrical stuff).
I was looking for an Autoranging True RMS meter in general. Most often used functions would be Voltage and Continuity test (which is fast on the 139C from what I've read). Backlight and Temperature weren't essential, but nice to have.
I'd like a Peak/ Min-Max mode that I could use to calculate the Crest/Peak factor of AC Mains voltage.
What's the difference between the Peak function on the UT-61E and the Min/Max on the 139C?
Will the Min/Max on the 139C show me the peak of a sine wave: 230 * 1.414 = ~320V (assuming a crest factor of 1.414 for a perfect sine wave)?
Offline Martini
« Reply #188 on: February 04, 2018, 01:49:21 pm »
No. It will display 0V or close.
EDIT: I have a question myself: which clamp can you use with it? Will it do DC current?
« Last Edit: February 04, 2018, 05:05:42 pm by Martini »
Offline Kbird
« Reply #189 on: February 04, 2018, 07:30:26 pm »
I ended up just getting the 210E and Modding it too since it was basically the same cost as an addon clamp but also gives me a 2nd Meter to Test with/compare , if needed.
KB
Uni-T UT-139C
MC-52-0055-6
Offline Martini
« Reply #190 on: February 04, 2018, 08:32:17 pm »
Well, the 139C has the min/max function :-+
Offline Kbird
« Reply #191 on: February 04, 2018, 09:13:52 pm »
I meant I got a 139C AND a 210E   = best of both worlds :) ...  not just a 210E , I got the 210E instead of an addon Clamp for the 139C as it was only a few $$ more at that time and it gave me a 2nd Meter for backup ....  the new 210E have a slightly better Chip now I believe.
Uni-T UT-139C
MC-52-0055-6
Offline Martini
« Reply #192 on: February 04, 2018, 10:00:42 pm »
Do you remember the clamp add-on reference?
Offline Kbird
« Reply #193 on: February 04, 2018, 10:34:27 pm »
I don't sorry AFAIK Uni-T never made one but I believe it is limited to 60Amp on the 139C. I think the Cheapest I found was $38 which made the 210E a no brainer for me...
something like these perhaps.... I do not have or recommend either of them ,,,I just had a quick look on Amazon...
perhaps wait for more replies
https://www.amazon.ca/dp/B00X3GDVWM/ref=sxbs_sxwds-stvpv2_1?pf_rd_m=A3DWYIK6Y9EEQB&pf_rd_p=3443526782&pd_rd_wg=Yfik6&pf_rd_r=BW2MG6BEH2YSDJBH6NNY&pf_rd_s=desktop-sx-bottom-slot&pf_rd_t=301&pd_rd_i=B00X3GDVWM&pd_rd_w=vVV3m&pf_rd_i=Clamp+Meter&pd_rd_r=0008d437-3747-4a38-bbb2-f1fe132dd42c&ie=UTF8&qid=1517782789&sr=1
https://www.amazon.ca/all-sun-Current-Working-Multimeter-Measurement/product-reviews/B013QH4K86/ref=dpx_acr_txt?showViewpoints=1
Uni-T UT-139C
MC-52-0055-6
Offline Martini
« Reply #194 on: February 04, 2018, 11:44:47 pm »
Clamp add-on seems like a shitty idea suddenly.
Offline carnage
« Reply #195 on: October 25, 2018, 01:37:27 pm »
Has anyone tried using Energizer Ultimate Lithium in the UT139C?
Did it work properly?
Offline Kbird
« Reply #196 on: October 25, 2018, 04:51:09 pm »
Have not tried them in the 139C
But I have/had them in a logitech mouse and they do strange things...one will drain to almost 0v  (0.404v) and the mouse becomes erratic as expected but if I leave the batteries out on the Workbench, a day or two later the battery is back to full Voltage.....has happened twice now but I am not using it in my Old Mouse any longer.... not sure if it is a drainage issue or what?
Uni-T UT-139C
MC-52-0055-6
Offline carnage
« Reply #197 on: October 28, 2018, 11:34:20 am »
I read that there was some Brymen meter don't like Energizer Ultimate Lithium.
Thanks for the reply!
Offline Kbird
« Reply #198 on: October 28, 2018, 04:16:54 pm »
Now I am curious ......what was happening with the Brymen?
The Lithium start out at high voltage .... like 1.78-1.81v .... the 2 I have used a while are in the 1.54-1.56 range though.
Uni-T UT-139C
MC-52-0055-6
Offline carnage
« Reply #199 on: October 28, 2018, 09:57:34 pm »
Here's the link where I read about the Brymen       https://www.eevblog.com/forum/testgear/the-bm235-does-not-accept-lithium-batteries/
Offline Kbird
« Reply #200 on: October 29, 2018, 12:10:21 am »
Thanks for the Link Carnage  :-+
*** looks like I was right about the initial 1.8v+ being too high (Over 3.6v total) when new....
However I am unsure if the 139C has the same limitation?
KB.
« Last Edit: October 29, 2018, 12:24:01 am by Kbird »
Uni-T UT-139C
MC-52-0055-6
Offline carnage
« Reply #201 on: October 29, 2018, 01:55:53 pm »
Can it cause any damage to the meter if I use the Energizer Ultimate Lithium?
Does the meter has any protection if the batteries has a higher voltage than what it call for?
Offline Kbird
« Reply #202 on: October 29, 2018, 06:27:47 pm »
I don't know sorry and as far as I have read the Manual does not mention Over-voltage on the Battery Power at all. ( may have missed it?)
Lower Battery Pwr warning light is 2.4v and the Meter will not work below 2.2v  ( backlight may not work below 2.6v or be dim)
Uni-T UT-139C
MC-52-0055-6
Offline carnage
« Reply #203 on: October 30, 2018, 11:34:35 am »
Will the Eneloop Pro work or any NiMH at 1.2V?
What are you using for batteries in your Uni-T UT139C?
Offline Kbird
« Reply #204 on: October 30, 2018, 06:09:51 pm »
Just standard AA Energizer currently , also use the Duracell AA
I have had issues over the years with NiMh 1.2v cells in different devices eg Camera gear etc , so I avoid them nowadays. I do have some 1.5v+ Pure Energy Rechargables but was worried about leakage as the Batts sit along time in a Meter so I didn't use them.
According to the Specs at 2.4v it will work but I am not sure if accuracy is effect as it turns off at 2.2v according to the Specs.
Perhaps try emailing Uni-T and ask for more details especially the Upper limit and if you can use the 1.8v Lithiums...
KB.
Uni-T UT-139C
MC-52-0055-6
Offline carnage
« Reply #205 on: October 30, 2018, 10:31:40 pm »
KB.
I have the Energizer Max I probably going to use if I can't find anything else to use. I had to many Duracell leak in my devices to use them.
Look like my Eneloops aren't going to work.
I tried emailing Uni-T twice with no reply.
I also tried emailing the seller, I'm just waiting for a reply.
Is there a Uni-T in the U.S.?
Offline Kbird
« Reply #206 on: October 30, 2018, 10:45:43 pm »
Not as far as I know , there is a Nth American Sales link , maybe worth a try?
Neo Chen - North/South America & Australia
Tel: (86-769) 8572 3888-306
Email: neo@uni-trend.com.cn
Uni-T UT-139C
MC-52-0055-6
Offline carnage
« Reply #207 on: October 30, 2018, 11:32:40 pm »
I just sent him a email.
Thanks for all of the replies!  I'll let you know what he said if I get a reply.
Offline carnage
« Reply #208 on: October 31, 2018, 11:35:36 am »
I got a reply from the seller. He said to use Zinc Carbon batteries.
I had to Google Zinc Carbon batteries to see what it is and if it available.
Does Zinc Carbon have or hold more power than alkaline and do they leak?
Offline HKJ
    • Tests
« Reply #209 on: October 31, 2018, 11:50:17 am »
Zinc Carbon is about 1/3 the energy of Alkaline and cannot deliver very high power, I have published a few test of them.
They are worse than alkaline with leaks.
Offline carnage
« Reply #210 on: November 01, 2018, 12:08:58 pm »
Thanks for the reply HKJ!
Do you think it would be safe to try Energizer Ultimate Lithium in the UT139C without any issue? Like shorting out something.
Offline HKJ
    • Tests
« Reply #211 on: November 01, 2018, 12:16:40 pm »
I would expect so, the DMM chip is rated for 3.6V operating and 4V maximum.
Offline carnage
« Reply #212 on: November 02, 2018, 10:32:58 am »
I'm going to get a pack of Ultimate Lithium.
Offline Kbird
« Reply #213 on: November 02, 2018, 04:16:12 pm »
If you have the same issue as the Brymen , then run them down to 1.6v in a flashlight and they should be fine , fresh my last pact was 1.82 or higher.
Post back please and let us know how it goes, thx.
KB.
Uni-T UT-139C
MC-52-0055-6
Offline soren
« Reply #214 on: March 11, 2019, 03:54:21 pm »
An unbranded version of the UT139C is currently on sale via Amazon Europe for EUR 10.99.
https://www.amazon.de/dp/B077ZQS94K
https://www.amazon.fr/dp/B077ZQS94K
https://www.amazon.es/dp/B077ZQS94K
I just received one and everything including probes and manual appear to be exactly like with the UT139C, except without the Uni-T name. If it's a clone, it is an extremely faithful one.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #215 on: March 11, 2019, 06:26:47 pm »
Offline stj
« Reply #216 on: March 12, 2019, 01:24:57 am »
i dont have a 139c, but if it uses the 0660 chip like the 210e or the aneng meters then it will run on eneloops etc.
i have been using ladda's in my 210e and 2 aneng's for over a year without problems.
Offline rsjsouza
  • Eternally curious
« Reply #218 on: March 12, 2019, 03:17:47 am »
This is a completely different meter.
Offline rsjsouza
  • Eternally curious
« Reply #219 on: March 12, 2019, 04:37:59 pm »
Wow... Amazon delivered it in about 24h. I wonder if this was just around the corner from here.
It really looks the real deal. It even has the Intertek listing number, although on a sticker and not indelllible.
I did not open it yet. Will do at the first opportunity.
« Last Edit: March 12, 2019, 05:37:26 pm by rsjsouza »
Offline hli
« Reply #220 on: March 14, 2019, 08:11:30 pm »
... appear to be exactly like with the UT139C, except without the Uni-T name. If it's a clone, it is an extremely faithful one.
Got mine from the german Amazon - 10.99 EUR delivered. Opened it up, and the PCB says 'UT139C' (look at the right side in yout photo). Compared to my older ones the PCB looks a little bit different. From the silkscrren it looks the old ones are at PCB revision -1 and the new one is at -4.
When I look at the product page now its at 39.99 EUR. So it seems to be a mistake on the sellers part...
Offline rsjsouza
  • Eternally curious
« Reply #221 on: March 14, 2019, 08:17:21 pm »
I opened mine and can attest it is a UT139C - same markings as yours, good input protection and excellent build quality. I even connected its inputs (ohm, continuity, diode, temperature, frequency) to a high voltage source and the meter did not even blink - a hint that the input protection is doing its work in protecting the meter.
Amazon US still has it for US$16.99 with Free shipping.
The following users thanked this post: Marco1971
Offline rogbese
  • Country: ng
« Reply #222 on: October 13, 2020, 11:43:39 am »
Hello!
Sorry to dredge up an old post. I just got this meter after reading thru this and was wondering on this new revision 5 board. The main chip is conned(?) and the location of the interface pins is different. I also notice an led? I'm thinking maybe a shared board? From others' experience, how good is this dmm in 2020 compared to the ut89x for bench work and basic home work?
Offline Fretec
« Reply #223 on: October 13, 2020, 03:22:44 pm »
Zinc Carbon, really? I wonder where he got this information from... This is ancient battery technology far inferior to alcaline (and everything else made these days).
Not sure if you can even still buy them, have not seen any for a long time.
