why the lack of high precision cheap ohm meters?
i have a 6000 count meter that isn't well known, but it uses the same dmm chip as several 60$ 6000 count meters that are well known.
and i find that the ohms portion is rather wacky.
the datasheet says the internal ic generates .63 volts and what i've been able to figure out (by having two meters)
is that the voltage generated (mine seems to output .643 volts) is connected in series with the 10M 1.11M, 101K, 10K, and 1K reference resistors. and also in series with a 900K resistor.
(figure 27, page 26)
http://www.ic-fortune.com/upload/Download/FS9922-DMM4-DS-11_EN.pdfwhat this means is, when the meter cycles through the ohms ranges, internal mosfets ground those 5 reference resistors, and then the adc compares .63 volts with the volts across the standard resistance.. unfortunately this means that 0 ohms is .60 volts dumped on the standard resistor. so i think the meter can be "Zero'd" by adjusting the value of the 900K ohm resistor.. Something to look for on your prized 60$ meters...
anyhow, i know that this dmm chip has a 60mV voltage range, and they use it for the 0-6 amp range of the 60 amp shunt (derated to 10 amps, its a full 5 milliohms)..
so i'm a bit peeved that they don't use the 60mV range to deliver you a legit 0-60.00 ohm meter.
if the meter can handle it, you might be able to change that 900K ohm resistor to 90K and just remember to divide by 10
divide by 100 would be better.. it would be nice to have a 0.001 to 6 ohm meter.. in fact i think that's about the most useful range for largish rotating machines..
edit: i believe my understanding of the ohms section is not complete, as i find connecting the meter to a negative .745 volts yeilds 1.093K, 10K, 100K and 1M ohm on the 6K, 60K,600K,6M and 60M ohm range. it reads over on the 600 ohm range.
Edit2: changing 900K ohms to 9K ohms doesn't change anything except the diode range, it reads .67 volts for a 67mv drop.
i changed it back to 90K and the resistance range settles faster, diode range is still broken.
