Author Topic: Old, new or PC?  (Read 2821 times)
Offline FrioTopic starter
Old, new or PC?
« on: April 06, 2018, 02:51:44 am »
Yes, yes, I have read the sticky about searching the forum for questions like these ;)
The issue is that for specific applications, the answers end up converging into different clusters and it takes a long time to search through all combinations of questions and answers...
At any rate, please bear with me, if you would.
I would like to purchase an instrument for two main purposes:
1) Analyze analog video signals, to diagnose issues with a machine that supposedly produces VGA VESA 640x480 output (~25MHz)
2) Analyze digital circuitry ahead of the DAC that produces said VGA output, and a variety of other digital busses that run at frequencies up to around 300MHz
I am vaguely aware of three main routes to achieve said results, and I would like to ask the experts here to weigh in on what makes the most sense (and bang for buck) with a budget of around $1500 (but I can be persuaded to spend some more if the advantage is substantial), or at least the pros and cons of each:
1) Old digital oscilloscope AND/OR logic analyzer, for example the Tek TLA714/715 (is it reasonable to analyze the VGA signal with a LA? perhaps with one analog and one digital board?)
2) New DSO/MSO from Rigol et al.
3) New PC-based combo of analog and digital scopes (are they fast enough?)
Thank you very much in advance!
Frio
Offline james_s
Re: Old, new or PC?
« Reply #1 on: April 06, 2018, 04:09:42 am »
Analyzing VGA signals is easy enough, but 300MHz digital buses? You'll need a relatively high end instrument for that. Are you thinking of serial or parallel buses?
Offline Fungus
Re: Old, new or PC?
« Reply #2 on: April 06, 2018, 07:09:27 am »
Easy/cheap.
Very expensive. You'd better be well paid for fixing whatever it is, if it's even possible to fix (what if it's a custom chip?)
Re: Old, new or PC?
« Reply #3 on: April 07, 2018, 03:45:29 am »
Thank you everyone for your comments!
Noone answered directly whether a TLA714 with both a 7DX/7EX and a 7NX/7NAX work for me?
Cheers!
Frio
Offline RomDump
Re: Old, new or PC?
« Reply #4 on: April 07, 2018, 04:37:42 am »
No one answered directly whether a TLA714 with both a 7DX/7EX and a 7NX/7NAX work for me?
You may want to do some research before you commit to the "TLA7Dx/Ex Digital Storage Oscilloscope Modules".  I don't think the module behaves like a traditional oscilloscope but I may be wrong.
It may be better getting two separate devices.
RomDump
RomDump
Offline RomDump
Re: Old, new or PC?
« Reply #5 on: April 07, 2018, 03:21:53 pm »
2) no it wont work because 7DX is a motherboard... http://www.tomshardware.com/reviews/Only-the-Best-9-Athlon-Motherboards-With-The-AMD-760-Chipset,351-16.html
What are you talking about? The 7DX he is referring to is the The TLA7Dx Oscilloscope module for the TLA714. He wanted to know if he should buy a logic analyzer with an Oscilloscope module for the video project he is working on.
RomDump
Offline james_s
Re: Old, new or PC?
« Reply #6 on: April 08, 2018, 12:17:56 am »
Well those big mainframe logic analyzers can usually be had pretty cheaply because it's not very often one has a need for those these days. Do keep in mind the probes can easily cost more than the unit if they don't come with it though.
I don't know anything about the scope plugins for them.
Re: Old, new or PC?
« Reply #7 on: April 08, 2018, 08:51:58 pm »
you dont get the answer because...
1) you just mentioned it..
maybe you can describe it in more detail because no one can read your mind... cheers.
Actually I did mention it in the sentence "Old digital oscilloscope AND/OR logic analyzer, for example the Tek TLA714/715 (is it reasonable to analyze the VGA signal with a LA? perhaps with one analog and one digital board?)".
I was referring to the fact that the 700 series can host a combination of logic analyzer and digital oscilloscope (TLA7D1, TLA7D2, TLA7E1, TLA7E2) boards...
Sorry I was not more precise.
Re: Old, new or PC?
« Reply #8 on: April 08, 2018, 08:53:02 pm »
RomDump
Understood, thank you!
I will ask a question in the forum to know if anyone has experience using the DSO modules for the 700 series.
Frio
Offline james_s
Re: Old, new or PC?
« Reply #9 on: April 08, 2018, 09:17:11 pm »
Maybe look for the user manual online? Or look for youtube videos?
The scope option on some of the older HP logic analyzers behaves pretty much like a DSO of the era. I'd have similar expectations for Tek, they practically invented the modern oscilloscope.
Re: Old, new or PC?
« Reply #10 on: April 08, 2018, 09:22:41 pm »
Thanks, I am trying to source information online, and I am sure the user manual gives all the required information, but it is huge :-)
If anyone on the forum can direct me to the appropriate information, it would save me a lot of time...
Frio
Offline RomDump
Re: Old, new or PC?
« Reply #11 on: April 09, 2018, 02:19:38 am »
Frio
For a faster response, you may want to email Gerry Man, (a local Canuk), as he mentioned he has one of those modules as well as a TLA715 on his blog.
RomDump
Re: Old, new or PC?
« Reply #12 on: April 09, 2018, 05:12:32 am »
Frio
Brilliant, thank you for the tip!
