I am interested on the value of touch screens on scopes from those who actually have scopes that support it.
Well, I predominantly use high end scopes that these days all have touch screens, so hopefully my input is of value to you.
Do you use the on screen touch panel where there are physical controls, or do you tend to use the physical controls?
That depends on what I want to do. For most of the basic settings I use the front panel controls, but there are occasions where I just want to enter a specific value (i.e. 10mV/div), and then I use the touch screen.
In addition, the scopes I usually use come with pretty advanced analysis functionality, something which is impossible to control via a few front panel buttons (unless you'd like your scope to come with hundreds of buttons).
I believe that some touch screen scopes have multi touch gestures, like stretch. Again, are they any use or do you tend to use the physical controls?
I use the touch screen, simply because it's much quicker and simpler.
Regarding touch-only features like Zone triggering: it sounds like a nice feature, and looks like it's nicely implemented on the Keysights, but realistically how often do you use such a feature?
I guess you think about Keysight's entry level scope DSOX3000T, where Keysight highlights zone triggering as a top feature. Fraonly, I'm not sure how useful this is. I do use advanced triggering regularly (i.e. parameter triggers looking for specific signal parameters or deviations), and on the scopes I use this is controlled via the touch screen. But on the low-end DSOX3000T it looks more like a marketing gimmick. At the end of the day, the DSOX3000T is a DSOX3000 with tacked-on touch support, and from what I've seen it looks and feels that way. It's more an attempt by Keysight to milk this old scope platform for a while longer.
Would you care to make other comments on the touch screen capabilities, particularly comparing it to the non-touch counterparts.
Well, that's difficult to say in general terms, as the touch implementations of the various manufacturers vary a lot.
For example, Keysight's scope UI for their high-end scopes, while having improved, has its origins in the old Infiniium 54800 Series and even in this day shows that it's an interface originally designed for mouse control and not touch, with touch a tack-on. It's good enough, but not great.
For Tek's UI it's roughly the same as with Keysight. Usable but not great, and clearly designed with mouse control in mind.
LeCroy's touch UI on their X-Stream scopes on the other hand is very good, but then LeCroy has designed it from the ground up as a touch UI (in fact, LeCroy was the first big brand to come up with a touchscreen scope when they brought out with the WaveMaster 8000 in 2001, and all mid-range and high-end scopes since then are touch based). They also have the most consistent UI, which means if you know how to operate a WaveMaster 8000 from 2001 then you can also operate a modern-day WaveMaster 8zi, WavePro 7zi or any other of their touch based scopes easily as the UI works the same.
R&S has touch interface in their RTO high-end scopes. I've seen a demo of it and then had time to play around with it for a few minutes only. However, the UI feels the same as the UI for other modern R&S gear, which is somewhat convoluted and illogical. They can do some nice tricks on their UI (i.e. multi-grid screens can be created quickly), finding the right settings can be a chore, and the many tricks of this UI worked much better on the connected Full HD projector than on the small XGA screen on the scope.
On a Keysight or LeCroy scope I'd happily use the touch screen as it's quick and efficient, but on the R&S RTO I'd probably try to stick to the buttons as long as possible (a lot of stuff can only be configured via touch). But I'm sure if I had to use the RTO every day then I'd get used to it's UI at some point (well, I did with my FSP7 spectrum analyzer, which also doesn't have the best UI).
I'm particularly thinking about the user interaction with the screen being vertically in front of you on the desk, more akin to a PC monitor than a tablet that you tend to use horizontally on your lap or table/desk. There had been some commentary about the ergonomics of touch screens for a traditional desktop use with Windows 8, liking it to a gorilla poke. Certainly although I use Windows 8/8.1 and have done almost exclusively since it came out, it is mostly in a non-touch desktop or laptop on desk environment. I only use the touch screen when I'm using it as a tablet on my lap.
A scope is no desktop PC, you hardly write letters or do other things that requires very extensive inputs on it. Plus, the screen is normally at the same distance from you as the scope's controls, so it doesn't matter much if you have to lift your arm to turn a knob or poke a screen.
In short, on a scale of 1 to 5, with 1 being "what touch screen" to 5 being "I couldn't live without it" what do you give the value of a touch screen on a scope?
I'd say a "2". Wouldn't say I can live without it but it would be a pretty big loss. But again, that's for a LeCroy or Keysight scope.
