Author Topic: Oscilloquartz STAR 4 GPSDO - RS232 output (lack of)?  (Read 3592 times)
Offline jpbTopic starter
« on: May 11, 2018, 07:41:34 pm »
Following advice on this forum I bought one of the Oscilloquartz Star4 based GPSDOs fro amoj1010:
https://www.ebay.co.uk/itm/10Mhz-GPSDO-OSCILLOQUARTZ-OSA-OEM-GPS-GPSDO-10MHz-1PPS-STAR-GPS-Clock/262861459973?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
It seems to work well even with the provided antenna, I have tested it against a recently acquired standard based on the 198kHz radio signal.
But I can't get anything out of the RS232 output. I have tried two usb to rs232 converters, most recently a very expensive industrial one.
Looking on my scope pin 8 shows the 1pps nicely, pin 2 (Tx) sits at -5.8V and pin 3 (Rx) sits at 0V (approximately).
Is there something I need to do to wake it up? I've tried connecting with Lady Heather, with Putty with a GPS display program and with PowerShell and get no response out of any of them.
Is it broken or am I doing something silly - I suspect the latter.
With other RS232 things I've found that you can send a *IDN? and get something out.
I've assumed the normal default baud rate of 9600.
Help :-//
Offline texaspyro
Re: Oscilloquartz STAR 4 GPSDO - RS232 output (lack of)?
« Reply #1 on: May 12, 2018, 03:42:55 am »
These things have their own command language.   They do not output anything unless commanded.  What version of Lady Heather are you using?  Did you specify the /rx4 command line option?
The following users thanked this post: jpb
« Reply #2 on: May 12, 2018, 10:55:22 am »
Thank you for replying.
I'm using version 5.0 (I've just downloaded it so assumed it was the most recent.) I've not tried /rx4 - I will give it a go.
Thank you very much - /rx4 did the trick (/5 to set COM5 and then /rx4). I thought it must be something simple I wasn't doing but my scan of the options didn't yield anything.
« Last Edit: May 12, 2018, 11:07:20 am by jpb »
Offline BravoV
  • +++ ATH1
« Reply #4 on: May 12, 2018, 11:09:01 am »
Get v6 here -> https://www.eevblog.com/forum/metrology/lady-heather-v6-beta-for-windows-exe/
Thankyou - I'll do that, though v5 is now working since I entered the correct /rx4 command. It is good to see the Tx and Rx lights flashing on and off on my RS232 after two evenings of nothing!
Offline BravoV
  • +++ ATH1
« Reply #5 on: May 12, 2018, 11:12:19 am »
Congratz,  and it will be much more exciting, once the "locked" sign pops up.  ;D
« Last Edit: May 12, 2018, 11:14:21 am by BravoV »
Offline Dwaine
« Reply #6 on: May 12, 2018, 01:53:40 pm »
I have the same device.  Works great.  I did the management modification and tapped the 10mhz square wave.
Offline Mrt12
« Reply #7 on: March 18, 2019, 12:25:02 pm »
what kind of management modification is this?
Offline texaspyro
« Reply #8 on: March 18, 2019, 07:13:19 pm »
The original packaged up version of this GPSDO brought the GPS receiver data out the RS-232 port.  Later version brought out the "management" interface that lets you monitor more stuff and configure some settings.  The modification swaps the RS-232 port from the GPS data to the management interface.   Lady Heather works with the management interface.
Offline Ohm_My
« Reply #9 on: June 04, 2019, 07:59:29 am »
Is their any way to get the RS232 enabled on the LEA-5T chip? So much more could be done with this GPSDO if the ublox u-center application could see it.
Offline texaspyro
« Reply #10 on: June 04, 2019, 05:41:07 pm »
I seriously doubt that...  like what could u-center bring to the party?
Offline Ohm_My
« Reply #11 on: June 18, 2019, 01:54:36 am »
Well for starters I could put the module in a fixed timing mode with a precise known location. I'm seeing a difference of location in the 24 hour survey that is run on unit startup versus several PPP observations that I have done that result in  <.013 meter accuracy.
