If you scrape it all away until it is clean and then you have in some spots no more PCB left, then you can fix the hole area as well.
In such cases, I have placed a heavy tape over the hole on one side and place the PCB flat and fill the hole with some 2 component
epoxy. This way you can start clean to lay some wires, you can even drill holes through the epoxy and create some connection to the other side.
It takes a lot of time, but it works.
