Author Topic: HP 3456A DIY serial read out  (Read 3172 times)
Offline HarvsTopic starter
« on: November 28, 2013, 11:11:39 pm »
With my 3456A now working, I was very keen to get the readings out of it and into the tablet app.  So I had a play around with the GPIB port last night.
Turns out to be very easy in Talk Only mode.
If anyone's interested in doing it, just grab a uC, attach the first 7 data lines, DAV and NDAC lines and the code's below.
Now to see if I can get my hands on the proper connector...
const int DAV =  10; // Data Valid
const int NDAC  =  11; // Not data accepted
byte data;
void setup() {
  Serial.begin(115200);
  pinMode(DAV, INPUT);
  pinMode(NDAC, INPUT);
  digitalWrite(NDAC, LOW);
  pinMode(2, INPUT); //D0
  pinMode(3, INPUT); //D1
  pinMode(4, INPUT); //D2
  pinMode(5, INPUT); //D3
  pinMode(6, INPUT); //D4
  pinMode(7, INPUT); //D5
  pinMode(8, INPUT); //D6
void loop()
  pinMode(NDAC , OUTPUT);
  if(digitalRead(DAV) == LOW){
    data = 0;
    if(digitalRead(2) == LOW)
      data |= (1<<0);
    if(digitalRead(3) == LOW)
      data |= (1<<1);
    if(digitalRead(4) == LOW)
      data |= (1<<2);
    if(digitalRead(5) == LOW)
      data |= (1<<3);
    if(digitalRead(6) == LOW)
      data |= (1<<4);
    if(digitalRead(7) == LOW)
      data |= (1<<5);
    if(digitalRead(8) == LOW)
      data |= (1<<6);
    Serial.write(data);
    pinMode(NDAC , INPUT);
Offline george graves
Re: HP 3456A DIY serial read out
« Reply #1 on: November 28, 2013, 11:24:04 pm »
subscribed!
« Reply #2 on: November 29, 2013, 02:44:27 am »
subscribed!
Do you have one of these meters?
Just thinking I could get a board made through itead with the proper connector and a USB + Bluetooth interface.  The connector is $5.50 from digikey, plus all the other parts, it'd probably cost around $20.  Would anyone else be interested?
Offline macboy
« Reply #3 on: November 29, 2013, 03:03:11 pm »
I like the trick of emulating an open-collector I/O by switching the pin between input and output(0). That's something not everyone thinks to do.
The only thing I would add is that you should ensure that all inputs are TTL level compatible (2.0 V and up is High). With CMOS level inputs, it may not work well.
