Nice, thanks for making this available. I have this unit, but mea culpa, have not had the time to take it apart.
Alas the photos don't have the best detail to make a more informed critique, its best if we can read the labels on the smallest components. If you can't get better photos I'll tear mine down and add to this thread when I can
Construction appears very good. I did not expect the power switch to be relayed by that plastic extender all the way to the rear, but that keeps AC line interference away from the board, a nice subtle touch rather than save money and move that switch up front.
The power amp on the lower left get obviously warm during operation, so it seems to work at a high quiescent temp even with outputted dialed very low. I like that the makers not only took time to insure the power resistor spacing has the proper clearance to cool them down, but they added insulators to their extended leads.
The ground planes on the main PCB are very generous so is the shielding you see below it.
Is there a mark on who the actual manufacturer is of the unit?
I like this unit, I use it a lot, it works very well and output is very stable. The 2 drawbacks I find is the DDS low pass output filter increases the rise time and rolls off the edges of the square waves, as expected. However you can get a clean fast square wave rise time from the unfiltered sync port, and the duty cycle adjusts this too. There is no cancel button so if you type in wrong values you can't clear your input and start over until it times out, or you overwrite it. A well spent $153 from tequipment.net, delivered.
