Author Topic: Profile/Thor Labs LDC400 Manual, anyone?  (Read 1534 times)
Offline nfmaxTopic starter
« on: June 24, 2018, 09:09:25 pm »
I have acquired a Profile (Thor Labs) LDC400 GPIB-controlled laser diode driver, fitted with an LDC402 current driver and a TEC420 temperature controller. I can't find any information about it, although I think I might have found the correct DB-9 connector pinouts (based on cable specifications). Before I start reverse-engineering it, does anyone have a manual? Any of a user guide, programming guide, service manual, application note or even a brochure would all be welcome!
Re: Profile/Thor Labs LDC400 Manual, anyone?
« Reply #1 on: October 08, 2018, 09:56:08 am »
Thanks to forum member Marc, I have been able to borrow & scan a copy of the original manual!
Offline HAL9000
« Reply #2 on: May 31, 2019, 02:48:59 pm »
I have exactly the same problem. Is the manual still available? Would be so much help, thanks!
Offline HAL9000
« Reply #3 on: June 04, 2019, 09:03:49 am »
Just an Update: nfmax sent me a copy of the original manual! I am now using the oldschool laser diode driver with no issues  :-+
Offline kambgr
« Reply #4 on: June 07, 2019, 01:35:16 pm »
Hi! I'm looking for the same documents.
Could you please help me?
« Reply #5 on: June 07, 2019, 01:39:46 pm »
To anyone wanting a PDF of the manual: send me a PM with your email address & I will send a (temporary) link you can download from. It's about 30MB in size!
