This PSU is still better than those found in Siglent or Rigol. Look at those big heatsinks and high quality electrolytic capacitors.
If this PSU was of low quality then there would be much more parts dead, not only 1 diode and 1 fuse. When a low-quality switched PSU goes off, then often transistors and even the main IC are burned, sometimes even the scope mainboard can be damaged.
For me, Keysight is still OK.
Was there an overvoltage in your power grid in Russia??
