Likewise, short of the "something" being a magical electron eater, every charge unit into something must exit it, since you can't create or destroy them. This is Kirchhoff's current law. What goes in must come out, or in other words, the sum of all currents entering a point (where positive currents leaving are equivalent to negative currents entering) is zero.
I've found that students often see this as unintuitive in the case of a charging capacitor, where they think that charge should enter one side, but not exit the other, because they imagine it like a "charge tank". The symmetry between "positive currents leaving" and "negative currents entering" shows why even this case will be symmetric, with charge moving in one side and out the other: the positive side charging to become more positive is the exact same thing as the negative side charging to become more negative.
