Author Topic: Hantek IDSO1070A 70MHz  (Read 2710 times)
Offline haggy38Topic starter
« on: March 09, 2017, 09:35:47 pm »
Hi guys,
Anyone had the chance to try this new wifi oscilloscope from Hantek?
iPhone/iPad/Android/Windows Oscilloscope, Multi-touch Operation.
WIFI Communication (USB Communication), WIFI Direct Connection/ Router Connection.
Build-in Lithium Battery with 4 hours endurance, no need of External Power. Floating Measurement is available, safe and convenient.
70MHz Bandwidth, Real-time Sampling Rate 250MSa/s
Can be connected with iPad and iPhone at the same time. When operating on iPad, it can also be observed on iPhone.
Good mechanical design. The outer case is made by the same material with iPad - Anodised aluminium. It has great heat resistance and abrasive resistance with beautiful appearance. The hardness of aluminium alloy surface is greatly improved
Small size which is convenient for traveling.
Software Support:IOS,Android(Unpublished),Win10,Win8, Win7, Windows NT ,VISTA, etc.
More than 20 kinds of automatic measurement function, PASS/FAIL Check function, fit for engineering application.
FFT spectrum analyzer
Waveform averaging, afterglow, lightness control, reverse, add, subtract, multiply, divide, X-Y display.
The waveform data can be output as EXCEL, BMP, JPG according to time and voltage.
Re: Hantek IDSO1070A 70MHz
« Reply #1 on: March 10, 2017, 10:45:15 pm »
No one?? :-\
