Probe use should NEVER assume frequency derating OR max probe voltages, to do so puts yourself and your scope at risk.
That funny graph on the bit of paper in the probe packet is to be kept and referred to regularly, especially when probing at elevated voltages and frequencies. It matters not what ANY other manufacturers ratings might be, the only thing that matters are the specs for the probe you are using. Significant variation across various 10:1 probe brands lead me to get cheap100:1 probes for safety and sanity.
Or,only use old Tektronix 10:1 probes!
I like the ones that were used on 545B's---"built like a brick dunny",they've already lasted half a century.
Not that big on frequency response,but good enough for a lot of work!
Strangely,the only time I have found it really necessary to use a 100:1 probe was for the high impedance,rather than the voltage division.
The equipment manufacturer suggested the use of an active probe with a high impedance.
It was a fairly rare adjustment.,& quite frankly,"Boss,I need an active probe to this specification" just wasn't going to fly.
The 100:1 had the right input impedance,the display was a bit noisy,but the tweak was "do-able",so it was "all good",& we ended up with a useful probe.
