I bought this unit very cheaply on Ebay. It's quite impressive in the inside I think.
Datasheet:
https://accusrc.com/uploads/datasheets/5930_ufx99ca.pdfMy unit has options U9opt01, U9opt05.
It had 75 Ohm inputs but actually it used minimum loss pads to convert from 50 Ohm. Everything else is 50 ohms inside. I've already removed the minimum loss pads and I need to replace them with attenuators. I've also removed and reused for the conversion of the unit to 50 ohm some of the connectors on back. (I don't need 4 external filters).
Unfortunately one of the 6 pole RF relays was stuck after some initial usage and burned the driver IC (over current). I found the same type relays on Ebay and they've already been installed on the pictures. After this event I found out that there's some extra noise (10kHz pulses, so the noise floor is not flat at those frequencies anymore) coming from the power supply which I removed to investigate. It's pictured separately. I don't have too much time to work on this so that why it's not fixed and installed back yet.
I've also dumped the software for the unit for backup purposes. I included that too.
Enjoy.
