Author Topic: Rigol DP821A Dual Output 140W Programmable DC Power Supply Impressions  (Read 596 times)
Offline MedSpark
  • Innovation Ignited
    • MedSpark Medical Product Design and Development
We're considering the purchase of a Rigol DP821A DC Power Supply and I'm wondering if anyone on this forum has any good/bad/ugly experiences with them. We're looking for something that has at least one channel at >50V+ @ >1A. Thanks in advance for the help!
« Last Edit: January 04, 2018, 03:47:15 pm by MedSpark »
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: Rigol DP821A Dual Output 140W Programmable DC Power Supply Impressions
« Reply #1 on: January 04, 2018, 03:54:54 pm »
Why not consider the 832A and series connect channel 1 and 2? That way, when you no longer need high output voltage, it's still a good triple output bench power supply.
Also, 832A is much more popular with much larger user base, which means hardware bugs are less likely to remain uncovered, and software fixes will be more frequent.
Offline MedSpark
« Reply #2 on: January 04, 2018, 03:59:19 pm »
Are there any drawbacks? Also, I thought that the 832A was only essentially a 2.5 channel unit, or am I mistaken?
Offline blueskull
  • Country: cn
« Reply #3 on: January 04, 2018, 04:18:15 pm »
CH2 and CH3 share ground, so you can connect CH1 negative to CH2 positive, and use CH1 positive as high voltage output, while CH2 negative as ground, you still have CH3 positive as a second channel.
Edit: typo
« Last Edit: January 04, 2018, 04:32:31 pm by blueskull »
Offline MedSpark
« Reply #4 on: January 04, 2018, 04:23:29 pm »
CH2 and CH3 share ground, so you can collect CH1 negative to CH2 positive, and use CH1 positive as high voltage output, while CH2 negative as ground, you still have CH3 positive as a second channel.
Thanks for the info. I'll consider it.
