Have been using DP832 for some time and starting to wonder, is there any alternative to this PSU with the following mandatory features:
- 3 independent channels
- at least 3 Amps
- back plate connectors with SENSE
- monitoring function analogue (ability to set some current that when reached the unit will beep)!
- more-less decent display
Searched a bit, but have found none for these functions. Closest are R&S HMC/HMP but these do not have monitoring function, only fuse/switch off.
Might be Keysight with firmware updates, but its manual does not indicate such a function (which is odd, it is so easy to implement, yet no one has done it except Rigol).
I would upgrade, since DP832 have several bugs/shortcomings.
